Which Tow Hitch
Mobbs
Are the rear tie down hooks easy to remove? It says i will have to remove them when installing my hidden hitch. Are these those two big metal hooks at the rear right and left side? If so they seem solid, any suggestions on how to remove them?
Never Mind found out it was just 3 bolts on each side.
Edited by Mobbs
Yeah, on my 02 the tow hitches were an easy three nolt removal... You may need to clean up the threads of the nut that did not have bolt in it originally (I did). I didn't have the correct size tap, so I cut some slots in one fo the old tow plate bolts with a die grinder and then deburred it on the wire wheel. Made a great make-shift thread cleaning tool. Just spray some lube in the nut first.
IIRC, Hidden Hitch, Draw-Tite and Reese are all the same company now, so be careful when comparison shopping.
If anything like my 02, you need a harness module as the brake and turn signal circuits are separate. The harness kit makes the wiring dead easy though.
Edited by BowTied
