Mobbs Posted September 9, 2008 Share Posted September 9, 2008 Does anyone have any recommendations on tow hitches for a 1997 Pathfinder? Link to comment Share on other sites More sharing options...
Pezzy Posted September 9, 2008 Share Posted September 9, 2008 I have a hidden hitch (er, had one)... they have a good name for themselves. U-Haul also sells hitches... Link to comment Share on other sites More sharing options...
daftpup Posted September 9, 2008 Share Posted September 9, 2008 YEP. class3 hidden hitch for me. Link to comment Share on other sites More sharing options...
Mobbs Posted September 9, 2008 Author Share Posted September 9, 2008 Awesome thank you, U-haul hu thats a great idea. Will look into the hidden hitch. Link to comment Share on other sites More sharing options...
Jarsiff Posted September 9, 2008 Share Posted September 9, 2008 I looked into uhaul myself, they have the proper tube style hitch and wiring kits. Link to comment Share on other sites More sharing options...
PathA4 Posted September 9, 2008 Share Posted September 9, 2008 etrailer.com for all your hitch needs. at least that's where I got our hidden hitch and the necessary connector hardware. Link to comment Share on other sites More sharing options...
Mobbs Posted September 9, 2008 Author Share Posted September 9, 2008 Ya, i found a hidden hitch online today for $150 shipped. I will also go to uhaul to price out one of theirs. etrailer.com - will have a look. Link to comment Share on other sites More sharing options...
Wetnwild Posted September 9, 2008 Share Posted September 9, 2008 Check out the design of the different manufacturers, some of them have hitches that sit lower than others. I prefer to have mine sit up close to the stock bumper. Link to comment Share on other sites More sharing options...
Mobbs Posted September 9, 2008 Author Share Posted September 9, 2008 Yeah that is exactly what i am looking for. I want it to sit pretty clean. My back bumper is a little messed up so i don't expect it to be flush. Link to comment Share on other sites More sharing options...
Mobbs Posted September 11, 2008 Author Share Posted September 11, 2008 (edited) Are the rear tie down hooks easy to remove? It says i will have to remove them when installing my hidden hitch. Are these those two big metal hooks at the rear right and left side? If so they seem solid, any suggestions on how to remove them? Never Mind found out it was just 3 bolts on each side. Edited September 11, 2008 by Mobbs Link to comment Share on other sites More sharing options...
BowTied Posted September 12, 2008 Share Posted September 12, 2008 (edited) Yeah, on my 02 the tow hitches were an easy three nolt removal... You may need to clean up the threads of the nut that did not have bolt in it originally (I did). I didn't have the correct size tap, so I cut some slots in one fo the old tow plate bolts with a die grinder and then deburred it on the wire wheel. Made a great make-shift thread cleaning tool. Just spray some lube in the nut first. IIRC, Hidden Hitch, Draw-Tite and Reese are all the same company now, so be careful when comparison shopping. If anything like my 02, you need a harness module as the brake and turn signal circuits are separate. The harness kit makes the wiring dead easy though. Edited September 12, 2008 by BowTied Link to comment Share on other sites More sharing options...
01LE Posted September 12, 2008 Share Posted September 12, 2008 Just to throw another one into the mix there's also Curt Hitches. Fleetfarm sells them for around $140-$150 and they have two different styles. Link to comment Share on other sites More sharing options...
