engine Q
Leman
thats a VQ30DE, 3.0 V6, so it would be terribly underpowered in an SUV, way slower than what u already have/had.
doesnt look like a direct fit. im sure u could bolt it in with some work but one has to ask WHYYY
That engine actually made more power and torque then the vg33 lol.
yeah with 14" wheels on a maxima, it make 190 hp
drop that into a suv that weights nearly twice as much, slap on those 31" tires, and watch what happens. It'll be WD21 status.
I think all the VG series motors used the same block so it may bolt up but the VG30DE heads are wider than the VG33E heads so getting it to fit may be an issue. According to wikipedia the VG33E produced 180/202 hp/tq @ the crank and the VG30DE produced 222/198 hp/tq @ the crank. So yes more power but less Torque and I belive the VG30DE was also a slightly higer reving engine with a steeper tq band where as the VG33E had a flatter tq band. In other words, at lower rpms the Vg33E will produce more a bit tq than the VG30DE making it bog more when pulling out or trying to cruise @ low to mid range rpm.
