ctpathy Posted July 18, 2008 Share Posted July 18, 2008 OK my pathy won't start, I turn the key and get nothing. It is in park and when I turn the lights and turn the key nothing the lights do not dim so i ran out tricks has anyone have this problem??? thank for any help Brian Link to comment Share on other sites More sharing options...
Simon Posted July 18, 2008 Share Posted July 18, 2008 Check the battery connections, make sure they're clean and tight. Failing that, try boosting it. Failing that, could be the starter. Link to comment Share on other sites More sharing options...
unccpathfinder Posted July 18, 2008 Share Posted July 18, 2008 b/c you owned a R50 B4 a WD21... I'd be willing to put $20 its a bad battery and/or connection from battery to starter..try a jumper like simon said... Link to comment Share on other sites More sharing options...
nige Posted July 18, 2008 Share Posted July 18, 2008 (edited) it could be a short in the same circuit that the parking interlock switch it on. The one that only lets you start the car if it's in park. i would check the battery first like the rest of the guys say. if it was the battery, once you get it running, check your alternator output too. Edited July 18, 2008 by skrillaguerilla Link to comment Share on other sites More sharing options...
ctpathy Posted July 18, 2008 Author Share Posted July 18, 2008 Check the battery connections, make sure they're clean and tight. Failing that, try boosting it. Failing that, could be the starter. I cleaned the battery connections moved the shift lever and bang she started . the pos connect is still a little loose i am going to replace it thanks simon and evreyone for the help. Link to comment Share on other sites More sharing options...
ctpathy Posted July 18, 2008 Author Share Posted July 18, 2008 b/c you owned a R50 B4 a WD21... I'd be willing to put $20 its a bad battery and/or connection from battery to starter..try a jumper like simon said... I never owned a R50 . So I am doing it right by having a WD21 LOL Thanks for the help Link to comment Share on other sites More sharing options...
Casey.T Posted July 18, 2008 Share Posted July 18, 2008 I never owned a R50 . So I am doing it right by having a WD21 LOLThanks for the help hehehehehehe :tonguefinger: Link to comment Share on other sites More sharing options...
unccpathfinder Posted July 19, 2008 Share Posted July 19, 2008 (edited) HAHA ...whoops I confused you with someone else (http://www.nissanpathfinders.net/forum/index.php?showtopic=18580)... I retarded & just got PWND Edited July 19, 2008 by unccpathfinder Link to comment Share on other sites More sharing options...
