95 se auto
ctpathy
OK my pathy won't start, I turn the key and get nothing. It is in park and when I turn the lights and turn the key
nothing the lights do not dim so i ran out tricks has anyone have this problem???
thank for any help Brian
Check the battery connections, make sure they're clean and tight.
Failing that, try boosting it.
Failing that, could be the starter.
it could be a short in the same circuit that the parking interlock switch it on. The one that only lets you start the car if it's in park.
i would check the battery first like the rest of the guys say. if it was the battery, once you get it running, check your alternator output too.
Edited by skrillaguerilla
I cleaned the battery connections moved the shift lever and
bang she started . the pos connect is still a little loose i am going to replace it
thanks simon and evreyone for the help.
b/c you owned a R50 B4 a WD21...
I'd be willing to put $20 its a bad battery and/or connection from battery to starter..try a jumper like simon said...
I never owned a R50 . So I am doing it right by having a WD21 LOL
Thanks for the help
