bbeck8176 Posted July 11, 2008 Share Posted July 11, 2008 Just picked up a pristine 87 with a vg30. After driving home I noticed the oil pressure gauge was at 0. The oil light still comes on when I turn the key. I pulled the oil fill off and I can see oil coming into the valve cover from the front, but it's not shooting out or anything. The truck runs great and doesn't make any strange noises. How do I fix the gauge? Or should I not worry about it? I picked up a sending unit from the parts store, could the gauge and the light run off the same sending unit? HELP! Link to comment Share on other sites More sharing options...
MY1PATH Posted July 11, 2008 Share Posted July 11, 2008 interesting... my '89 doesn't have a guage just a ligt that shines red @ startup and I think I saw it yellow once when I may have been low. Anyway I would assume that the light and the guage would run off the same sensor but maybe somone else can provide better info since I don't even have a guage. wellcome to NPORA BTW Link to comment Share on other sites More sharing options...
Casey.T Posted July 11, 2008 Share Posted July 11, 2008 check the oil sending unit on the passenger side above the starter(look through the front passenger wheel well) Link to comment Share on other sites More sharing options...
bbeck8176 Posted July 12, 2008 Author Share Posted July 12, 2008 Check it for what? Link to comment Share on other sites More sharing options...
Alkorahil Posted July 12, 2008 Share Posted July 12, 2008 Check it for what? There is a wire that goes to it. I believe it is a green wire. See if it is covered with oil/crud/junk and not making a connection and/or not plugged in. If that doesnt fix it replace the oil pressure sensor. PART NUMBER: 25070-07G12 Link to comment Share on other sites More sharing options...
bbeck8176 Posted July 13, 2008 Author Share Posted July 13, 2008 Well, it is covered with oil. I ordered a new sending unit today, and while I was leaving the parts store the starter crapped out. So now I'm going to need a starter. Damn it. Link to comment Share on other sites More sharing options...
MY1PATH Posted July 14, 2008 Share Posted July 14, 2008 Well, it is covered with oil. I ordered a new sending unit today, and while I was leaving the parts store the starter crapped out. So now I'm going to need a starter. Damn it. I seem to have read that here a few times before.... The Oil PS sensor gets loose and leaks on the starter and then the starter craps out. I better double check mine. Link to comment Share on other sites More sharing options...
Alkorahil Posted July 14, 2008 Share Posted July 14, 2008 I seem to have read that here a few times before.... The Oil PS sensor gets loose and leaks on the starter and then the starter craps out. I better double check mine. Yep yep yep. common problem with the VG30. Throw a little bit of pooky on the threads once you start threading the sensor back in. Link to comment Share on other sites More sharing options...
Casey.T Posted July 14, 2008 Share Posted July 14, 2008 Well, it is covered with oil. I ordered a new sending unit today, and while I was leaving the parts store the starter crapped out. So now I'm going to need a starter. Damn it. Been there done that, next.... Link to comment Share on other sites More sharing options...
