silver97ex Posted July 6, 2008 Share Posted July 6, 2008 Hey guys, I have a 95 Pathy SE. vg30e I believe. I just wanted to verify that I have to pull the crank pulley off during this whole process. I plan on doing the timing belt while I'm in here too. No need to do this twice right? My Chiltons manual isn't all that detailed so.... Any help would be much appreciated Link to comment Share on other sites More sharing options...
Slick Posted July 6, 2008 Share Posted July 6, 2008 Chiltons manuals suck. but yes, if you are going to change the t belt while yer in there (good idea) then the TP has to come off. be sure not to lose the little "key" when the pulley comes off. Link to comment Share on other sites More sharing options...
Precise1 Posted July 6, 2008 Share Posted July 6, 2008 Read this... http://npora.ipbhost.com//index.php?showto...t=0&start=0 That should help a bit. Another 'replace while you are there' item is the coolant bypass hose. You may want to get one and replace it... B Link to comment Share on other sites More sharing options...
silver97ex Posted July 7, 2008 Author Share Posted July 7, 2008 Thanks for the replys. That write-up is for the vg33, is it similar to the vg30? Link to comment Share on other sites More sharing options...
88pathoffroad Posted July 7, 2008 Share Posted July 7, 2008 Exact same procedure. Link to comment Share on other sites More sharing options...
