mattr67 Posted May 26, 2008 Share Posted May 26, 2008 I have a 1995 pathfinder and when i turn on the blinkers it makes a buzzing noise and the blinkers dont work. but the hazards do. i replaced the flasher thing and that didnt help, any suggestions? thanks Link to comment Share on other sites More sharing options...
Simon Posted May 26, 2008 Share Posted May 26, 2008 Check to make sure the hazard switch, when turned off, comes back out all the way. I once had a piece of paper towel jam in there after a cleaning, and it caused the exact issue you describe. Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 26, 2008 Share Posted May 26, 2008 IIRC there's a hazard flasher and a separate flasher for turn signals. Link to comment Share on other sites More sharing options...
94extreme Posted May 26, 2008 Share Posted May 26, 2008 yes, separate switches. could be either one making it bonkers. Link to comment Share on other sites More sharing options...
mattr67 Posted May 26, 2008 Author Share Posted May 26, 2008 i found the hazard flasher. where is the other flasher at? Link to comment Share on other sites More sharing options...
94extreme Posted May 26, 2008 Share Posted May 26, 2008 should be in the same area. follow the sound? Link to comment Share on other sites More sharing options...
falconer Posted May 30, 2008 Share Posted May 30, 2008 (edited) Happened to me in my '94 not long ago for one of my blinkers, turned out to be a blown fuse and one of the wires had disconnected because someone had rewired it. Edited May 30, 2008 by falconer Link to comment Share on other sites More sharing options...
