TheCROW163 Posted April 30, 2008 Share Posted April 30, 2008 Hey guys, just a quick question: I'm planning to change the battery on my 98SE all stock Is there anything I should know? How can I do this without affecting or resetting the ECU or messing with any other settings of the truck? I'm afraid to mess up something. Also what specs should the battery be? Thankyou. Link to comment Share on other sites More sharing options...
Simon Posted April 30, 2008 Share Posted April 30, 2008 Battery should be at least 650 CCA. Make sure it's a model that fits in the battery spot in the engine bay. Some are too tall. Your parts store should know this. Unless you can clamp the posts, with jumper cables to another battery, then take off the terminals, and reattach them to the new battery, you'll have your truck disconnected. It's no big deal. Reset the clock, and your station presets, and go. Link to comment Share on other sites More sharing options...
TheCROW163 Posted May 1, 2008 Author Share Posted May 1, 2008 Thanks Simon for the reply. I have no problem with the clock and radio resetting, but I don't want anything else to reset or be affected in the engine or electricals or sensors Link to comment Share on other sites More sharing options...
navygz19 Posted May 1, 2008 Share Posted May 1, 2008 (edited) You sure do come up with a lot of questions Parts stores can tell you the info. you need. As far as reconnecting, make sure it's positive first, then negative of course. You will loose your trip mileage info. and all presets in the radio (unless you have an after market deck...that may save them) No need to worry about the ECU. Also, if you have auto. climate control it will revert back to 75 degrees (I think) blowing on your face. Edited May 1, 2008 by navygz19 Link to comment Share on other sites More sharing options...
t0ast Posted May 1, 2008 Share Posted May 1, 2008 before you pickup the battery, check for corrosion on the terminals. I had to replace mine after they dissolved when I took them off the battery. Link to comment Share on other sites More sharing options...
TheCROW163 Posted May 2, 2008 Author Share Posted May 2, 2008 OK great, thanks a lot for the info. I appreciate it! Link to comment Share on other sites More sharing options...
BowTied Posted May 2, 2008 Share Posted May 2, 2008 good info above. Always disconnect negative first and reconnect negative last. Link to comment Share on other sites More sharing options...
