NOVA_mudfinder Posted January 20, 2008 Share Posted January 20, 2008 My E brake light keeps coming on when i usually hit about 15 miles/hour and I know my brake is all the way down so any input would be nice thanks. Link to comment Share on other sites More sharing options...
XPLORx4 Posted January 20, 2008 Share Posted January 20, 2008 My E brake light keeps coming on when i usually hit about 15 miles/hour and I know my brake is all the way down so any input would be nice thanks. It's not the "e-brake" light, it's the "Brake" light, of which the emergency brake is only one part. A glowing "Brake" light indicates either that the emergency brake is engaged or that the brake fluid reservoir is low, due to the pads and shoes becoming more worn, or a leak in the system. Check the remaining brake pad material left, and if the pads do not need replacing yet, then add a little brake fluid to the reservoir. But closely monitor your brake pad wear so you know when it's time to replace them! Link to comment Share on other sites More sharing options...
