Re: http://www.nissanpathfinders.net/forum/index.php?showtopic=11862
systemf
I am pretty sure that the QX4 auto is the same the tranny in the R50s?
Will this shift kit work in our electronicly controlled trannys?
The model listed in the FSM is the same as the kit.
ALso, does anyone know if the t-case adapter that bolts onto the end of a 4x4 auto with a TX10 and be unbolted and replaced with the adapter for a ATX14A if they do have a different input bolt pattern?
It also fits the Nissan/Infiniti RL4R01A transmission,
hmm.... Unless I miswrote down the number mine is RE4R01A...???
The name threw me off, I knew I knew a systemf... didnt know why... must be too early for my brain. Welcome to NPORA (Finally! :tongue:)
correct, it will work after checking this out and I am pretty sure an R50 auto with a tx10 will work on the QX4 with the ATX14 since the output adapter for each t-case will interchange and the QX4 lists the same model for the auto.
Thanks for the welcome
Is your 4x4 on a knob or a lever??
If i have a 4x4 knob or lever won't matter as that is in the xfer case and the tranny to t-case adapter will bolt/unbolt from tranny to tranny. What would matter is my engine, and I do have the VG33E.
Edited by systemf
