Lifting And Towing Points
DaveS
i was wondering what the lifting and towing points are for a wd21 pathy i don't have a receiver hitch so where is a good point to toe someone with and if i get a high lift is there any place that i can place the jack without crushing something.
i usually use my grill guard and hitch.... there are no places to use a hi-lift on a stock pathy. frame slider fab time!
I wish i had a hitch but i don't are there any other places to hook a tow line into on the back???
yup. i have a D shackle in one but have never used it yet and i've had in there for a few years. lol.
so those tabs on the frame are strong enough to tow i saw them there but i wasn't sure if they could handle the weight of towing somebody.
thx for all the help Dave
yeah.. pulling straight back they are ok.. sideways you'll have to be really careful as they will bend like sammy said.
yea and im saying i wasnt even pulling from those tow points....i had my strap around my rear axle :)
if you can hook to both of those rear points, its OK. but not a good Idea. I used to use them, any sideload and they bent flat up. rear axle is good. but its a PITA. also watch for brakelines.
if you rip the rear bumper off, you can rap a strape around the rear most crossmember.
in a pinch I had to use my hilift on the front of my path. at that time I had a stock bumper and put the hilift under the bumper, right where the bumper braket is. the bottom of th bumper bend a bit, but I did lift the front end off the ground(one side at a time).
