Fuel Injector Help
PATHRIDER
hey guys need your quick assistance please. Im trying to replace my injector No.5 and does anyone know which one it is? I looked in the service manual and it doesnt give me the injector numbers.
Youre help is much needed ..Thanks fellas
Thanks for the fast reply guys. Yes the spark plug wire still connected ghost.
I knew youd come thru for me simon:D ..So its just like the plug configuration...1-3-5 on the left side looking from the front and 2-4-5 on the right?
Rearmost would be the closest to the firewall right?
I shouldve asked you guys first and saved me the trouble of removing the plenum..I thought for sure its 1-2-3 from the left(pass side) and 4-5-6 right side (driver side)thinking that the number 5 injector is the one directly below the plenum.
Any suggestions on what I should do in there while I got the plenum out?
Thanks again guys
Thanks red...got it replaced ..i need to put the plenum back in tomorrow morning and while im at it I might replace some of the hoses that looks real old. Also found out that the vacuum hose that gets disconnected all the time when replacing plug 6 is cracked.
Thanks for the help guys
