NoKaOiSURF Posted July 17, 2007 Share Posted July 17, 2007 aloha will a ecm from a 93 4x4 5spd work on a 95 4x4 5spd mahalos plenty Link to comment Share on other sites More sharing options...
GhostPath Posted July 17, 2007 Share Posted July 17, 2007 aloha will a ecm from a 93 4x4 5spd work on a 95 4x4 5spd mahalos plenty IIRC, it *should*, but it won't support OBD-II. Link to comment Share on other sites More sharing options...
unccpathfinder Posted July 17, 2007 Share Posted July 17, 2007 95 isnt OBDII...cross check the #'s not the huge # but the actual part numbers... Link to comment Share on other sites More sharing options...
NoKaOiSURF Posted July 17, 2007 Author Share Posted July 17, 2007 95 isnt OBDII...cross check the #'s not the huge # but the actual part numbers... where can i cross ref. the part #? Link to comment Share on other sites More sharing options...
GhostPath Posted July 17, 2007 Share Posted July 17, 2007 95 isnt OBDII...cross check the #'s not the huge # but the actual part numbers... The numbers won't match. Nissan changed them about every year. I wasn't sure if 95 were OBD-II on Nissans. They are on Jaguars. That said, you can use any MPFI Pathfinder ECU (90-95) in any other MPFI Pathfinder of the same drivetrain - auto trucks need auto computers, manual trucks can actually use either but an auto computer in a manual truck might set an error code - harmless and it won't affect anything. Now, the fuel mappings will be subtly different, but at least your truck will run. Link to comment Share on other sites More sharing options...
TerranoNZ Posted July 17, 2007 Share Posted July 17, 2007 The numbers won't match. Nissan changed them about every year. That said, you can use any MPFI Pathfinder ECU (90-95) in any other MPFI Pathfinder of the same drivetrain - auto trucks need auto computers, manual trucks can actually use either but an auto computer in a manual truck might set an error code - harmless and it won't affect anything. Now, the fuel mappings will be subtly different, but at least your truck will run. 2nded....I've got an ECU out of a 93 in my 91 Link to comment Share on other sites More sharing options...
NoKaOiSURF Posted July 17, 2007 Author Share Posted July 17, 2007 The numbers won't match. Nissan changed them about every year. I wasn't sure if 95 were OBD-II on Nissans. They are on Jaguars. That said, you can use any MPFI Pathfinder ECU (90-95) in any other MPFI Pathfinder of the same drivetrain - auto trucks need auto computers, manual trucks can actually use either but an auto computer in a manual truck might set an error code - harmless and it won't affect anything. Now, the fuel mappings will be subtly different, but at least your truck will run. Shootz......Thanks for da fast reply.. I call up the guy that got the ecm and give a try.... Aloha Link to comment Share on other sites More sharing options...
