mikeysentra Posted July 7, 2007 Share Posted July 7, 2007 I have been doing some looking and It is hard finding aftermarket wheels in a 15" size. where can I find desent looking wheels that arent 17" or bigger for my 97 pathfinder? Also where can I find urethane bushings? I have looked @ the obviouse places but cant seem to find them from Energy suspension of prothane! any ideas? I am trying to cure a wobble in the rear of my pathfinder going over bumps on the freeway @ 70. one in perticular can really put an unsettling jerk in the rear of my pathy going over this perticular expansion joint. Thanks Link to comment Share on other sites More sharing options...
XPLORx4 Posted July 7, 2007 Share Posted July 7, 2007 Try 4wheelparts.com for 15" wheels. Try 4x4parts.com for polyurethane bushings. The wobble in your rear is caused by worn rear trailing arm bushings. Here is a trailing arm that has been fitted with poly bushings purchased at 4x4parts.com: Link to comment Share on other sites More sharing options...
02silverpathy Posted July 7, 2007 Share Posted July 7, 2007 Hey XPLORX4 can you give detail about the diffeences in the arms you have pictured? Please! Link to comment Share on other sites More sharing options...
denisb Posted July 7, 2007 Share Posted July 7, 2007 (edited) Hey XPLORX4 can you give detail about the diffeences in the arms you have pictured? Please! Looks like one had a fair bit of contact with a solid object......rock maybe The second one seems to have been built for someone atissipating one such thing by reinforcing the bottom of it........just a guess tho. Edited July 7, 2007 by denisb Link to comment Share on other sites More sharing options...
XPLORx4 Posted July 7, 2007 Share Posted July 7, 2007 (edited) Looks like one had a fair bit of contact with a solid object......rock maybe The second one seems to have been built for someone atissipating one such thing by reinforcing the bottom of it........just a guess tho. Bingo! Other details include: one is dirty, one is painted. Edited July 7, 2007 by XPLORx4 Link to comment Share on other sites More sharing options...
nissandoms47 Posted July 8, 2007 Share Posted July 8, 2007 And one has angle iron just welded on the bottom lol. Link to comment Share on other sites More sharing options...
mikeysentra Posted July 8, 2007 Author Share Posted July 8, 2007 thanks for the info. geez urethane bushings arent as cheap as they were for my Sentra and Eclipse, oh well I guess I need to just do it and not worry about the cost. anyway after doing some more looking under my pathy I seem to have a trailing arm on the right rear that is also slightly bent. I guess I need to make a trip to the wrecking hard and get a used replacement for when I do the bushings. Link to comment Share on other sites More sharing options...
88pathoffroad Posted July 8, 2007 Share Posted July 8, 2007 Haven't you learned yet that NOTHING for a Pathy is easy to find or cheap? Link to comment Share on other sites More sharing options...
nissandoms47 Posted July 8, 2007 Share Posted July 8, 2007 Lol, I would highly recommend armoring those control arms. The angle iron i welded onto mine has already payed off. Link to comment Share on other sites More sharing options...
mikeysentra Posted July 8, 2007 Author Share Posted July 8, 2007 Yeah the more I look the more I find that its not cheap to play with the pathfinder. I will get some angle iron when I do the bushings and the new trailing arm, and reinforce them. Link to comment Share on other sites More sharing options...
