Daddy Rim Posted June 23, 2007 Share Posted June 23, 2007 As the title says, I'm looking for a wiring diagram for the IPF fogs in my ARB. I have two mystery wires, while the other I believe to have properly figured out. Thanks Link to comment Share on other sites More sharing options...
csutke Posted June 23, 2007 Share Posted June 23, 2007 :worthless: Link to comment Share on other sites More sharing options...
88pathoffroad Posted June 23, 2007 Share Posted June 23, 2007 Er, how many wires do you have on each? It should be a fairly simple setup. Link to comment Share on other sites More sharing options...
vengeful Posted June 23, 2007 Share Posted June 23, 2007 http://coloradok5.com/wiringlights.shtml Link to comment Share on other sites More sharing options...
tmorgan4 Posted June 24, 2007 Share Posted June 24, 2007 I had that exact question when I put mine on since it didn't come with a diagram either. I called ARB and they were helpful. Look for a post I made on this quite a few months back. Can't find it here. Link to comment Share on other sites More sharing options...
Daddy Rim Posted June 24, 2007 Author Share Posted June 24, 2007 (edited) http://coloradok5.com/wiringlights.shtml Already googled and found that link, but thanks just the same. They're setup is rather different and they're wiring diagram doesn't coincide with my setup. My questions lie primarily with three wires, numbers 1,3 and 4 in my picture above. #2 I assume is a ground. 1 3 & 4 are I'm assuming, relay inputs of some sort, but I was hoping to get some clarity on which inputs they were. Thanks Edited June 24, 2007 by Daddy Rim Link to comment Share on other sites More sharing options...
88pathoffroad Posted June 24, 2007 Share Posted June 24, 2007 Relays have two wires just to operate, a ground and a 12V in to turn it on. The other two wires should be 12V main in fused supply and 12V output(s). It could also share grounds for the lights, but that's kind of unusual. Unplug the wiring plug from the relay and look inside there to see if there are any numbers beside the tabs. Should be a 30, 86, 87, etc...go by any generic relay wiring diagram from there. Link to comment Share on other sites More sharing options...
