SaKaNa Posted June 8, 2007 Share Posted June 8, 2007 Has anyone actually tried installing an oil cooler in an R50? It seems like the Hayden 291 can fit on a 96-98 Pathfinder.. I'm looking to do some cooling on nearly any fluid I can, and I figure an oil cooler cant hurt. Anybody have any advice on how to do this? Link to comment Share on other sites More sharing options...
88pathoffroad Posted June 10, 2007 Share Posted June 10, 2007 You'd need to tap and install oil line fittings on the block and oilpan (I think) or just get an external oil filter kit and use high-pressure hose to put the oil cooler inline with the external filter. I plan on running an oil cooler when I put my filter kit and headers on, just for that added security. It's a good idea, just not really necessary. Link to comment Share on other sites More sharing options...
SaKaNa Posted June 10, 2007 Author Share Posted June 10, 2007 Does anybody know if this would fit? http://www.amazon.com/Hayden-Inc-291-Coole...5706&sr=8-2 Link to comment Share on other sites More sharing options...
nissandoms47 Posted June 10, 2007 Share Posted June 10, 2007 I would just use one made for an xterra,frontier. The only difference in the oil filter mount is that the R50 points the oil filter straight down so it can clean the PS pump bracket while the frontier has it at a 45 degree angle outward for easier access because the ps pump is mounted on the other side. Link to comment Share on other sites More sharing options...
SaKaNa Posted June 10, 2007 Author Share Posted June 10, 2007 But will the frontier one fit without any modifications? I;m not one to liek screwing around and modding mods just to make them work on my Pathfinder. Link to comment Share on other sites More sharing options...
nissandoms47 Posted June 10, 2007 Share Posted June 10, 2007 It should bolt right on. That is if those oil line fittings on the engine side unscrew so you can screw the adapter on. Link to comment Share on other sites More sharing options...
