Rear Sway Bar
87pathfinder4banger
i've got a question. my rear sway bar has had one of it's linkages broken a month ago 4x4'ing. i know that this gives me more flex offroad, but it is causing the body to roll big time and Im not sure if this is gonna cause my shocks to be overworked and decrease their lifespan as i have just installed them. does anyone know this?? 88', i'm guessing you do??
No...that's what they're supposed to do anyway. I wouldn't worry about it. What you should worry about is either overextending or compressing a shock too far. That could damaged the inner rebound bumpers and blow an oil seal on the shock itself.
I took off the rear bumpstops is that a badthing??
My truck has alot of flex but im not sure if im overextending the new shocks 1 1/2 to almost 2 feet of flex with the JGC springs too
if it is a bad thing where do i get new bumpstops at??
mine are bad ( I tried cutting them in half )
