CRASS PUNK Posted April 28, 2007 Share Posted April 28, 2007 ok heres the deal i went in to get me oil changed no big deal they crack the cases check everything and change the air pressure in my tires i pay they tell me everything looks good. i get in and for some reason it feels lower. didnt think about it. get on the freeway and tire are hella loud i get home check the pressure its at 28 in all 4 kinda mad thinking this was just some moron that messed up i got back they look it up in there lil computer and it says 28psi kinda confused i asked them to air it back where they were. they did anyone else ever had this done i looked on the door and sure nuff it said 28 for the 31 in. tire i would think if i had ran on 28psi i wouldnt have any tread left in 3 months why is the oem standard so low anyone know? Link to comment Share on other sites More sharing options...
yozsi Posted April 28, 2007 Share Posted April 28, 2007 huh? 28 isnt low. i run 26 in the summer and 28 in the winter months on my 31's. Link to comment Share on other sites More sharing options...
88pathoffroad Posted April 28, 2007 Share Posted April 28, 2007 Depends on what tires you have, I guess. My Swampers run at about 24-26 on the street. Link to comment Share on other sites More sharing options...
daver123 Posted April 28, 2007 Share Posted April 28, 2007 my bfg a/t's are 35 psi max and i run 'em just a little lower, about 30. Link to comment Share on other sites More sharing options...
CRASS PUNK Posted April 29, 2007 Author Share Posted April 29, 2007 wow when i got my tires rotated they told me to set the at no more then 40 and no less then 35 i have the toyo open country a/ts i just though that it was really low Link to comment Share on other sites More sharing options...
Slick Posted April 30, 2007 Share Posted April 30, 2007 (edited) on my 31" michelins it says max of 45psi...... i run them at 34-38 depending if i am towing the boat or retrieving trailers for work..... off road.... 22-28 my 33" STT's are max rated @ 35psi..... i run those about 32. off road about 18-22 depending on conditions Edited April 30, 2007 by Slick Link to comment Share on other sites More sharing options...
forrer13 Posted April 30, 2007 Share Posted April 30, 2007 I seem to remember hearing you should go off the posted pressure on the inside of the door jamb, rather than the poster pressure on the sidewall of the tire. You should also remember the tires will gain some pressure as they get warm. Link to comment Share on other sites More sharing options...
Pavelow Leaks Posted May 1, 2007 Share Posted May 1, 2007 the psi on the sidewall is the max pressure, for max load, I run my bfg at's @ around 30 on the street, and about 12-15 off road. And I fill them with nitrogen so temperature changes don't affect them. Link to comment Share on other sites More sharing options...
jj big shoe Posted May 1, 2007 Share Posted May 1, 2007 I seem to remember hearing you should go off the posted pressure on the inside of the door jamb, rather than the poster pressure on the sidewall of the tire.That info is meant to be used for vehicles with stock tire size and the brand that came on it originally. Once you change the factors you supposed to go with the tire manufacturer's suggestions. I fill my 32" BFG A/T's to about 35, although right now they're at 40 for better mileage since I just drove down to Key West and back for a wedding. 17mpg baby! BTW, the tires on monster trucks are at about 10psi. Go figure. Link to comment Share on other sites More sharing options...
Smithk Posted May 1, 2007 Share Posted May 1, 2007 35-39 PSI on my Pro-Comps X-terrains for street. Link to comment Share on other sites More sharing options...
Chriskaw440 Posted May 1, 2007 Share Posted May 1, 2007 I filled mine with dirt so I never have to put air in them. Makes the pathy kind of heavy though. Link to comment Share on other sites More sharing options...
meangreenmachine Posted May 4, 2007 Share Posted May 4, 2007 The psi on the door is for stock pathys under "normal" or should i say suburban driving. Like it has been stated many factors change the ideal amount of pressure you should run. How old are your tires and have you run the same pressure in them the whole time. If so I would look at the wear on them. If they are worn more in the middle than the out sides i would lower the pressure. If they are wearing more on the outsides i would raise it. Link to comment Share on other sites More sharing options...
