SantaCruz163 Posted April 15, 2007 Share Posted April 15, 2007 Since I probably killed one of my O2 sensors because of an exhaust leak right at the bung I am going to replace all 4 of them. Right now I have Bosch sensors but am looking at other options at this point. Dealer wants something rediculous like $190 per sensor, and being that I'm getting 4 I am not going to drop like $800 on freakin sensors. I was looking on AutoPartsWarehouse.com and found different manufactures for sensors; Denso, Walker Products, Bosch, 'Standard', SNG. From peoples experiences, what is the better sensor to go with? My mileage is down to something retarded like 10mpg and I need to do something about, especially with prices the way they are going. Link to comment Share on other sites More sharing options...
Acey Posted April 15, 2007 Share Posted April 15, 2007 (edited) Your dealership sucks. The list price on them is $140 each. Pinnacle has them for around $109 each. Edited April 15, 2007 by Acey Link to comment Share on other sites More sharing options...
turbopath Posted April 15, 2007 Share Posted April 15, 2007 I would get denso's as they are likely the same thing the dealer sells. Also, I would only replace the front two. The set after the cats really don't have much bearing on mileage etc. They're just there to see if you have cats on or not. (You could spend 40 bucks on a little box and delete them too I bet) Link to comment Share on other sites More sharing options...
SantaCruz163 Posted April 15, 2007 Author Share Posted April 15, 2007 Well since I am already running Bosch after cat sensors, will it screw with the ECM if I run a different model sensor pre-cat? I was looking and the location of the pre-cat sensors and it looks like a PITA to get them out. What is the best tool to remove them. Seems like a socket wouldn't work because of the sensor wires and such. And, you recommend Denso sensors because chances are that's what the dealer sells? Link to comment Share on other sites More sharing options...
nissandoms47 Posted April 15, 2007 Share Posted April 15, 2007 Autozone rents out an 02 sensor removal tool. you need to remove the heatshield to do the front sensors. Link to comment Share on other sites More sharing options...
