LSD Swap?
MikeV
I just bought a 95 XE automatic, as my 95 manual trannie frame broke. I had to get to work and back, no time to disassemble and weld (above rear axle by gas tank)
Question is my XE has drum rears, SE has disc: is it easier to swap out the entire axle as the drum style has a thrust block I believe from previous reading.
Both are LSD, I have to put my rancho 9000's & 4" springs in back anyways.
more than likely replace a few more parts while I am in there to keep her driving strait.
Just making sure I am not creating more work for myself.
I am going to POR-15 this frame as it is from a place where road salt didn't live!!!
-bounce-
MV
They should be different. Disc brakes require considerably more pressure than a drum, so a disk/drum setup has to have something (usually called a proportioning valve) to significantly reduce the pressure to the drum end. I'm assuming it is incorporated in the master cylinder on Pathy, but I don't know for a fact. I know it is a seperate component on my Chevy.
THANKS!
You guys ROCK, :bow:
I will be swapping the rear axle and the master cylinder then.
Again Thanks!
I will be having some spare parts soon (In WI)
My 95 manual's frame is 2 far gone for me to repair, so I bought the 95 auto.
Love my Nissans!
(Just sold my 91 Z TT ) :(
no more breaking the sound barrier for me! It was the Pathy or the Z!
Do I have to pull covers and count teeth or are their "model" #'s to tell me what the gear ratio is?
It is definately wierd getting in without the lift! :(
Thanks again guys (& gal)
:aok:
Never had to look at it as it always worked without any issues, my buddie changes my fluids as he has a "pit" in his garage. I was raised in a UAW family so I was "learned" on ford n' chevy. When I bought my first Nissan (71 240Z) I was almost disowned.
I got as far as the brakes and noticed the drums, been stuck in Algona, Iowa for 2 weeks doing server upgrades so I couldn't physically look at anything, when I get home I will have at least 4 days of time off to work on the swap. So if I asked the questions now I can just get it done when I escape hell here in Iowa.
Thanks Again! :beer:
Mike
