Pulling codes off a 2001 Pathfinder?
Gripenfelter
The easiest way is to simply go to autozone and get it check there for free. They will tell you what the code is, and usually what it means. They can even clear it for you.
They use an OBDII scanner, they are quite costly. You don't have anything like an autozone or possibly an advanced auto? If you can't do that, just take it to your mechanic and he'll check it out.
Are there any online diagnostic programs you can download?
I have the OBD I and OBD II cables with the proper adapter to connect them to the USB port on my laptop. I normally use them for flashing PCMs on Camaros and Firebirds.
