putting in suspension
ShadowManR6
im lookin to replace stock shocks/ucas/springs, to a 3"
while the boys are flogging the dead horse (and rightly so, this subject has been covered a LOT).. try trail master, rough country.... and look in your year specific thread, this subject has been flogged to death with every conceivable suspension combination, parts lists, prices, vendors.... etc. :beer: :contract:
Edited by Slick
if it ends up being that myself and friends go to put it in, im just making sure i won't encounter any conflicts if i try to replace one thing, if it even makes a difference, before replacing another.
everyone seems to be suggesting to buy all the pieces independently in place of buying a complete kit, and me being new to this, i'll probably be back maken sure i got everything on the checklist (NO QUESTIONS ON WHAT BRANDS JUST MAKEING SURE I HAVE THE PART!!!!) pssd pssd
Edited by ShadowManR6
As for the shocks themselves, thats the easiest, 2 bolts each. I personnaly think you could do either-or, but just make sure that you dont need it for a day....do the front then the back, or vise versa...The rest is pretty easy too, took a few hours for the rear, then a few for the front.....for me.
Edited by govols74n
My UCA's took a while to do, as even though I bought new spindles, I didn't have the hardware for them, so I had to pull that off the old UCA's. That took a while, as 12 years of rust made them pretty tight. The removal/install, though, was quite easy. Shocks are part of the UCA job anyways, as you have to undo the top mount for the fronts. Rears are simple. Rear coils are also easy.
Basically, in a day, working slowly, there's no reason you couldn't have the full lift in.
hahahaha... countless semi-flaming posts, yet nobody actually answered the question of what order to do things. :rolleyes: I'd say all shocks first (and reinstall last), then:
Front- ball joint first (popped loose AND the 4 bolts on top), then UCA at frame, dismantle spindle, etc.
Rear- rear tires off and jack stands on rear frame, Ebrake cable guides, lower axle down with jack, then pull springs
As far as front vs. back, it doesn't really matter. Re-install it in reverse order. Test drive, then check all your fasteners, etc.
