tranny cooler
Guest SuperSon
Guest SuperSon
Good morning all.
Hey guys , where can I locate the factory tranny cooler on a 93 pathy? Looking from the front I see a couple of hoses just below the crank pulley to the left is a couple of hoses I think its about 3/8 or maybe 1 inch hoses that goes underneath the rad.Cant tell for sure if those are the 2 hoses that I need.
If I remember correctly from 88's tutorial the input that goes on the aftermarket cooler is the one thats going to have pressure when the motor is cranked (spits oil out)
Help!!!!!!!
Edited by SuperSon
Guest SuperSon
When I pull those 2 hoses in the bottom of the rad do I have to do anything to the input and output of that factory cooler like plug it or something.Im completely going to bypass it
Well, maybe just to keep contaminants from getting into it. Plug it up, maybe if you can find a couple of short bolts that'll screw in. That should help the life of your rad a bit.
You can use some rubber vacuum caps to plug off the stock holes, or leave them open if you want. It won't have anything in it anymore and I doubt dirt will hurt it if you're not going to use the stock cooler anymore. I think the driver's side hose is the pressurized line. IIRC.
Guest SuperSon
Thanks man. Thats the part I was thinking of just dont know what its called.
I took a pic of what I think are the 2 hoses for the factory cooler.Please verify :D
