flnl Posted August 5, 2009 Share Posted August 5, 2009 Bringing the topic back to life Almost a year ago, when I bought a body lift, also bought rear quick disconnects from AC, but haven't installed them yet Now I'm going to do it, but it seems to be much longer than stock sway bar links, at least 4 inches longer. Even considering 3" of suspension lift, I guess the sway bar ends will sit 1" lower than it does with stock links on place. Did anyone noticed the same about AC quick disconnects? Any issues? Link to comment Share on other sites More sharing options...
GrimGreg Posted August 5, 2009 Share Posted August 5, 2009 As long as both ends of the bar are at the same level it will still function properly. Link to comment Share on other sites More sharing options...
headpeace Posted August 5, 2009 Share Posted August 5, 2009 Only issue I had was having to take the bar to a machine shop to have them drill the the holes out larger because I couldn't do it with a hand drill, but I have since just takin it completely off, didn't notice any difference in handling Link to comment Share on other sites More sharing options...
flnl Posted August 5, 2009 Share Posted August 5, 2009 The disconnects I have are 4"1/2 longer than stock links, as I could see the sway bar end will be pointing down the ground. Maybe I'll shorten it a bit and drill new holes for the clips. Link to comment Share on other sites More sharing options...
