SantaCruz163 Posted February 14, 2007 Share Posted February 14, 2007 I'm going to change the fluid in my tranny (manual) and front/rear diffs. Only problem is, I don't know what I should be using. My Trans Am used Dextron III ATF in the T56 (6spd) and I'm not sure if there is a certain fluid I should be using. Diifs.... I don't have the slightest idea. Thanks. At 150k miles, is it worth switching to Mobil 1 synthetic oil, or should I continue with regular dino oil? Link to comment Share on other sites More sharing options...
CALPATHY Posted February 14, 2007 Share Posted February 14, 2007 (edited) After reading on this forum (and the manual): Engine 5-30 Manual trans: 75-90 GL4 only, didn't look up AT since I don't have it Front and Rear diff: 80-90 GL-5 if you have a limited slip then it needs to meet the spec for limited slip Transfer: ATF Dexron I just replaced all of mine with synthetic, Castrol 5-30 for engine, Redline MTR 75-90 for trans, Redline 75-90 for diff and synthetic ATF Dexron III for transfer. It may be my imagination but my Pathy seems quieter. I am not sure if the synthetic is hype or not, but thought I would give it a try (albeit an expensive one). Edited February 14, 2007 by CALPATHY Link to comment Share on other sites More sharing options...
SantaCruz163 Posted February 14, 2007 Author Share Posted February 14, 2007 Thanks for the info. Is there a code on my door jam I should look for to see if I have a limited slip diff? Link to comment Share on other sites More sharing options...
CALPATHY Posted February 14, 2007 Share Posted February 14, 2007 Thanks for the info. Is there a code on my door jam I should look for to see if I have a limited slip diff? I don't think so. If you have an SE model then you should have the limited slip. Also, there was a tag on my diff that said to use limited slip gear oil only. Lastly, if you jack up the rear end and turn the wheel if they both turn in the same direction it is a limited slip, if they turn opposite direction it is not. Link to comment Share on other sites More sharing options...
CALPATHY Posted February 14, 2007 Share Posted February 14, 2007 (edited) BTW, you should download a manual for your Pathy here: Pathy manuals Edited February 14, 2007 by CALPATHY Link to comment Share on other sites More sharing options...
SantaCruz163 Posted February 15, 2007 Author Share Posted February 15, 2007 Nice, I tried looking for one on torrentz but never had luck. Thanks. Link to comment Share on other sites More sharing options...
CALPATHY Posted February 15, 2007 Share Posted February 15, 2007 Nice, I tried looking for one on torrentz but never had luck. Thanks. No worries. This manual is a lot better than the Hanes. Link to comment Share on other sites More sharing options...
