DJ Dank Posted February 1, 2007 Share Posted February 1, 2007 I am planning to do the rears myself and have someone do the fronts. From what I've read it should be relatively simple. Question: Is a rear alignment necessary after doing the rear? I know it is up front when installing the lift but what about the back? Link to comment Share on other sites More sharing options...
RWC5S2 Posted February 1, 2007 Share Posted February 1, 2007 I did the AC lift on my 2003 Pathfinder and there was no need to do anything to the rear. Only the front and you do need the camber bolts. Link to comment Share on other sites More sharing options...
DJ Dank Posted February 1, 2007 Author Share Posted February 1, 2007 How many bolts did you end up buying? I've heard some people not needing any, some people picking up 2(1 per side), and some using 4(2 per side). Found some Ingalls from Summit that are a pretty good deal. Summit Racing Link to comment Share on other sites More sharing options...
88pathoffroad Posted February 1, 2007 Share Posted February 1, 2007 I didn't think it was possible to align a solid rear axle. Link to comment Share on other sites More sharing options...
DJ Dank Posted February 1, 2007 Author Share Posted February 1, 2007 LOL thats what I thought but I recall reading somewhere at some point that it should be done. Link to comment Share on other sites More sharing options...
RWC5S2 Posted February 1, 2007 Share Posted February 1, 2007 I ordered the bolts at the same time as the lift kit. Think they were another $20.00 and only needed 2, one per side. If you add any strut spacers you might need longer camber bolts but verify with the experts at NPORA. I want to add spacers to my rig but kinda fear messing up the CV joints/angles/etc. Link to comment Share on other sites More sharing options...
4x4le Posted February 1, 2007 Share Posted February 1, 2007 dont buy any. If it needs the bolts, the shop will be able to install theirs and they will probable be cheeper than ac sells them for. I have 1 per side and they are only 1.75" adjustible unlike the 2" ones that ac carries Link to comment Share on other sites More sharing options...
TerranoNZ Posted February 5, 2007 Share Posted February 5, 2007 I didn't think it was possible to align a solid rear axle. BFH *runs back to WD21 thread* Link to comment Share on other sites More sharing options...
