Rear alignment necessary?
DJ Dank
I am planning to do the rears myself and have someone do the fronts. From what I've read it should be relatively simple. Question: Is a rear alignment necessary after doing the rear? I know it is up front when installing the lift but what about the back?
I ordered the bolts at the same time as the lift kit. Think they were another $20.00 and only needed 2, one per side. If you add any strut spacers you might need longer camber bolts but verify with the experts at NPORA. I want to add spacers to my rig but kinda fear messing up the CV joints/angles/etc.
dont buy any. If it needs the bolts, the shop will be able to install theirs and they will probable be cheeper than ac sells them for. I have 1 per side and they are only 1.75" adjustible unlike the 2" ones that ac carries
