Power Surge!
El Pathfindero
ok heres the dillemma:
i start the truck, runs fine until you put it in drive, then it will tend to kill over if you let the rpms fall below 1000, then it surges a few times and kills over,
if you press on the brakes when its in drive its even more prone to dying on me
HELP!!!!
I've tried using heet and fuel injector cleaner in my fuel and it helps a little, but with the weather anywhere from -22 to 45 degrees every week here, it still does it after warming up for ten minutes.
El P
no heated garage-only dorm room parking lot and storage unit with no heat :huh:
will check vaccuum and booster this weekend, those were what my roommate said to check. in school from dawn till dusk, so it'll have to wait till this weekend when i have daylight
