mikesmaximase Posted May 5, 2004 Share Posted May 5, 2004 Just wondering how you take off the shifter knob (if possible) on the transfercase shifter on a 95 Pathfinder. I tried unscrewing it, but that was a no go. There is no clip on it that can be taken off, and then slid off. ?????? Or do I have to unbolt it from undernieth. I just put a 3" body lift on my Pathfinder and now need to either heat up the rod or get one from a Nissan pickup truck. I have taken all the bolts out of the center console and its ready to come out, but I need to get the knob off so the boot will slide off of lever. Heres a picture of my Pathfinder with the 3" body lift, sorry its so dark out. Link to comment Share on other sites More sharing options...
statikuz Posted May 6, 2004 Share Posted May 6, 2004 Just the knob? Mine twists off... did you crank on it hard enough? =) Link to comment Share on other sites More sharing options...
sw Posted May 6, 2004 Share Posted May 6, 2004 thats lookin real good Mike what did you do in the end anyway???? Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 6, 2004 Share Posted May 6, 2004 I think mine unscrewed, but there's a generous amount of glue or threadlocker on the inside of the knob. Fun stuff. Link to comment Share on other sites More sharing options...
Mookie Posted May 6, 2004 Share Posted May 6, 2004 It's a toughy! I wrapped a rag around mine to protect it, then put vice grips on it to break it loose. Link to comment Share on other sites More sharing options...
MatterHorn Posted May 6, 2004 Share Posted May 6, 2004 I must be the only guy who didn't have to notch or bend the tcase shifter ... mine works fine ... I only wish it were longer ... Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 6, 2004 Share Posted May 6, 2004 I had to bend mine AND cut the floor out to get it to fit. o.o Link to comment Share on other sites More sharing options...
sw Posted May 6, 2004 Share Posted May 6, 2004 im with you Matt i didnt have to touch mine Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 6, 2004 Share Posted May 6, 2004 Maybe I didn't bend mine enough. Seriously though, when I was done with my BL, the shifter just plain hit the edge of the floor and stopped WAY short of being in 4LO...I checked! Link to comment Share on other sites More sharing options...
mikesmaximase Posted May 7, 2004 Author Share Posted May 7, 2004 Yeh, mine was way off of being able to go into 4-lo, it would go into Nuetral fully but stopped right there. I got the tortch out and heated it up and bend the rod, but I bent it to far, so tomorrow while at work I got to rebend it back a little. But anyways the knob was on there wicked tight. I had to get out my macanics gloves to get a good grip to get it off and Im not weenie, I got muscle. HAHAHAHA! Link to comment Share on other sites More sharing options...
Mookie Posted May 7, 2004 Share Posted May 7, 2004 Intially I thought mine was ok. On the street on level ground, it would just barely go into 4lo. I found out on the trail that once torque was applied, it wasn't locked in enough and would just pop out. I had to bend it and notch the floor. Link to comment Share on other sites More sharing options...
MatterHorn Posted May 7, 2004 Share Posted May 7, 2004 interesting ... i'll have to test that out ... I've never had to use 4wd after putting my body lift on ... i'll have to check it out ... hey ... aren't the hardbody shift levers longer too? ... even it it was like an inch longer that would be sweet ... Link to comment Share on other sites More sharing options...
Mookie Posted May 7, 2004 Share Posted May 7, 2004 interesting ... i'll have to test that out ... I've never had to use 4wd after putting my body lift on ... i'll have to check it out ... hey ... aren't the hardbody shift levers longer too? ... even it it was like an inch longer that would be sweet ... Yes, the Harbody shifter lever is what you want. Now if I had the patience to grab one at the junkers, it would have been a whole lot easier Link to comment Share on other sites More sharing options...
