bio93 Posted December 30, 2006 Share Posted December 30, 2006 I've only had this pathy for a couple weeks, and it's been too many years since my last one for me to remember. The idle seems high to me when the engine is cold. It idles anywhere from 1600 - 2000 rpm till it warms up. Is this normal? I've never had a fuel injected vehicle cold idle that high. Link to comment Share on other sites More sharing options...
89_trailboss Posted December 31, 2006 Share Posted December 31, 2006 seems fine to me. Link to comment Share on other sites More sharing options...
88pathoffroad Posted December 31, 2006 Share Posted December 31, 2006 It's fairly normal, but it may be idling a BIT higher than usual due to crustage/carbon/soot on all the sensors, throttlebody, etc. Check all your vaccuum hoses, too. They tend to dry out and crack at the ends where they plug in, allowing vaccuum leaks. Link to comment Share on other sites More sharing options...
94extreme Posted December 31, 2006 Share Posted December 31, 2006 sounds about normal. maybe tad high at the higher range. check what 88 mentioned and maybe look at the TBI just for kix. clean it v. gently if the wires are crusty. Link to comment Share on other sites More sharing options...
bio93 Posted December 31, 2006 Author Share Posted December 31, 2006 Thanx guys. Much appreciated. Link to comment Share on other sites More sharing options...
Jdpathy Posted December 31, 2006 Share Posted December 31, 2006 Mine is the opposite, I run around 500 rpms in gear and 600 in neutral Link to comment Share on other sites More sharing options...
NismoSkyZ Posted December 31, 2006 Share Posted December 31, 2006 This is very normal. I have had this happen with all my cars and it just idles higher simply to warm up. Link to comment Share on other sites More sharing options...
nissandoms47 Posted January 1, 2007 Share Posted January 1, 2007 seafoam the motor, i noticed a huge difference when i did mine.. Link to comment Share on other sites More sharing options...
Guest SuperSon Posted January 2, 2007 Share Posted January 2, 2007 how do you go about seafoaming the motor? Mines started acting funny for the last few weeks . Id sit on the stop light and it would sometimes idle high too and theres times the the idle would fluctuate :confused: Maybe its just the lenght of time that I warm it up, but after it warms up it runs great. Link to comment Share on other sites More sharing options...
88pathoffroad Posted January 3, 2007 Share Posted January 3, 2007 GOOGLE IT Link to comment Share on other sites More sharing options...
Guest SuperSon Posted January 3, 2007 Share Posted January 3, 2007 THATS THE ANSWER I WANTED TO HEAR. WHAT IS THIS FORUM FOR ? Link to comment Share on other sites More sharing options...
94extreme Posted January 3, 2007 Share Posted January 3, 2007 there was a topic on here on seafoming a while back. not sure where or when but if you want it you can probably find it. i think it boiled down to: follow the directions on the can. lol Link to comment Share on other sites More sharing options...
Guest SuperSon Posted January 3, 2007 Share Posted January 3, 2007 (edited) I did some searching thru google and in case anyone hasnt done it yet heres a link. This seem to be a great solution for cleaning motor and fuel system but havent tried it yet myself. The reason why I also asked in this forum is because some who has used it might have some negative feedback on this product. Sea foam Benefits of Using Sea foam Edited January 3, 2007 by SuperSon Link to comment Share on other sites More sharing options...
Adam Posted January 3, 2007 Share Posted January 3, 2007 THATS THE ANSWER I WANTED TO HEAR. WHAT IS THIS FORUM FOR ? this thread got me to google sea foam, and i just did a sea foam treatment because of said googling... guess this forum has a purpose after all Link to comment Share on other sites More sharing options...
