Guest SuperSon Posted December 7, 2006 Share Posted December 7, 2006 Howzit going all. Just need to double check on the gear oil that I need to use when I do my change this coming weekend. Im not going to change the tranny oil coz its still reddish just like it was the first time I had it changed. On the transfer case I was told to use Dextron3 ATF since its automatic but if it was manual it should be GL4. On the diff its GL5 75-90 . Correct me if Im wrong on this guys :type: Link to comment Share on other sites More sharing options...
mikemike Posted December 7, 2006 Share Posted December 7, 2006 whats the year on your pathy, i'll see if i can confirm those numbers at work tomorrow Link to comment Share on other sites More sharing options...
94extreme Posted December 7, 2006 Share Posted December 7, 2006 On the transfer case I was told to use Dextron3 ATF since its automatic but if it was manual it should be GL4. that would be the transmission itself. on the TC, earlier years call for gl and later for atf. Link to comment Share on other sites More sharing options...
mikemike Posted December 7, 2006 Share Posted December 7, 2006 transfer case will probably just be ATF 75-90 should be right, but i will try and confirm that at work tomorrow Link to comment Share on other sites More sharing options...
88pathoffroad Posted December 7, 2006 Share Posted December 7, 2006 Mine takes 80-90 gear oil for the t-case. Says so in the FSM. It depends on the year, not which transmission you have. Link to comment Share on other sites More sharing options...
wheel366 Posted December 7, 2006 Share Posted December 7, 2006 If you have a 94 like your profile says, you should use 80w-90 I believe. I used amsoil 75w-90 since that was what was available and it's some pretty damn good stuff. Link to comment Share on other sites More sharing options...
mws Posted December 7, 2006 Share Posted December 7, 2006 (edited) I know the following is correct for pre-'90, others will (please) confirm for all WD21's through '95. Manual trans: GL-4 gear oil, 75W90 or 80W90, about 5 L see: http://www.nissanpathfinders.net/forum/index.php?showtopic=2621 Transfer case: GL-4 gear oil, 75W90 or 80W90 Front diff: GL-5 gear oil, 75W90 or 80W90 Rear diff: GL-5 gear oil, 75W90 or 80W90 GL-4 is for regular gears, GL-5 has special additives for hypoid gears (like in diffs) where there are high "slipping" loads. Usually sulfer based, which explains why they stink. Use ONLY GL-5 in differentials. Conversely, you do NOT want to use GL-5 in manual transmissions as it is very hard on the synchros and will lead to eventual failure. GL-4 ONLY. I think you would be able to get away with GL-5 in transfer case, but I would recommend sticking to the GL-4. For GL-4, many of us are using Redline MT-90. Outstanding lubricant, but priced accordingly. About $9 per quart from Summit racing. For GL-5, many of us use Redline 75W90 Gear Oil. This is OK to use in open, LSD, or Lockrite equiped differentials. Edited December 7, 2006 by mws Link to comment Share on other sites More sharing options...
Guest SuperSon Posted December 7, 2006 Share Posted December 7, 2006 (edited) Thanks guys.Sorry I forgot to mention what year pathy. I have a 93 with automatic transmission. I cant remember where I seen a post on gear oil for the tranny.It specificaly says not to use GL4 on auto trans but I believe the tcase would take GL4 regardless if its auto or manual just what 88 said Edited December 7, 2006 by SuperSon Link to comment Share on other sites More sharing options...
wheel366 Posted December 7, 2006 Share Posted December 7, 2006 The auto takes atf. The transfer case takes atf. For 90 - 95. He has an 88 hence the name. I just did this last year. Well, I didn't do the auto since I have a manual, but you get what I mean. Link to comment Share on other sites More sharing options...
Guest SuperSon Posted December 7, 2006 Share Posted December 7, 2006 Got it :cool2: Thanks again Link to comment Share on other sites More sharing options...
mws Posted December 7, 2006 Share Posted December 7, 2006 The auto tranny needs auto tranny fluid. Confusion on the transfer case comes about because it is a relatively undemanding application. It's just regular gears turning in roller bearings in a sealed case, with minimal thermal demands. Without pumps, synchros, valves, hypoid gears, or any other special things with special needs, it will do fine with just about any old lubricant of approximately the right weight. I'll wager it will work adequately well under average use with motor oil, ATF, or just about any grade of gear oil heavier than 3 in 1 oil but thin enough to flows. Link to comment Share on other sites More sharing options...
94extreme Posted December 7, 2006 Share Posted December 7, 2006 ... it will do fine with just about any old lubricant of approximately the right weight. I'll wager it will work adequately well under average use with motor oil, ATF, or just about any grade of gear oil heavier than 3 in 1 oil but thin enough to flows. lol.. yeah. i switched from atf to gl in my t-case.. it smelled funky for 3-4mo or so but no issues at all. the funny thing is that a nissan tech told me that it would even be ok to mix gl and atf in the tc. Link to comment Share on other sites More sharing options...
