ntwrkguy1 Posted November 6, 2006 Share Posted November 6, 2006 The keyless remote on my '97 SE is acting strange. The 'lock doors' and 'alarm' buttons work, but the 'unlock doors' button does not. However, the unlock door button had worked prior to last week. I thought it might be the battery getting weak, so I threw in two new batteries. My results were the same -- the unlock door button still didn't work. I then even tried the reprogramming steps that I found when searching the archives. Again, everything but the unlock button worked. Any thoughts? Or is it time for me to hit eBay for some new remotes? Thanks, Ntwrkguy1 Link to comment Share on other sites More sharing options...
4x4le Posted November 6, 2006 Share Posted November 6, 2006 If your power doorlocks inside the truck work then it is most likely that the contacts on you unlock button on your remote are messed up. Next time you see someone with nissan keys laying around steal them and take the remote off. Then throw the keys away. Take the remote and program it to your truck. If that works, steal someone elses keys and do the same. That way you have a back up. And if your more honest of a person than me, yea, just hit up ebay. Link to comment Share on other sites More sharing options...
FUELER Posted November 6, 2006 Share Posted November 6, 2006 Next time you see someone with nissan keys laying around steal them and take the remote off. Then throw the keys away. Link to comment Share on other sites More sharing options...
nissandoms47 Posted November 6, 2006 Share Posted November 6, 2006 this happened with my keyless remote. when you press the unlock button does it press down more then it usually would? it turns out in mine that the actual button inside the remote got disconnected from the solder or w/e and fell away from its seat. so if thats the case you gotta get a new remote. Link to comment Share on other sites More sharing options...
QuismO Posted November 6, 2006 Share Posted November 6, 2006 this happened with my keyless remote. when you press the unlock button does it press down more then it usually would? it turns out in mine that the actual button inside the remote got disconnected from the solder or w/e and fell away from its seat. so if thats the case you gotta get a new remote. yep, this is what happened to my cousins 98 keyless remote. the button has 4 solder points at each corner (the button sits in a square housing). An easy solder job if youve soldered before. Link to comment Share on other sites More sharing options...
ntwrkguy1 Posted November 7, 2006 Author Share Posted November 7, 2006 this happened with my keyless remote. when you press the unlock button does it press down more then it usually would? it turns out in mine that the actual button inside the remote got disconnected from the solder or w/e and fell away from its seat. so if thats the case you gotta get a new remote. When I press the unlock button down, it does depress a little more than usual. I looked at the soldering on the contacts, and it looked fine. What's strange is that both of the remotes I have are doing the same thing with the unlock button. It's probably time to hit up eBay! Link to comment Share on other sites More sharing options...
ntwrkguy1 Posted November 7, 2006 Author Share Posted November 7, 2006 If your power doorlocks inside the truck work then it is most likely that the contacts on you unlock button on your remote are messed up. Next time you see someone with nissan keys laying around steal them and take the remote off. Then throw the keys away. Take the remote and program it to your truck. If that works, steal someone elses keys and do the same. That way you have a back up.And if your more honest of a person than me, yea, just hit up ebay. Thanks for making my Monday -- this response had me laughing out loud! Link to comment Share on other sites More sharing options...
