suspension lift
stock shocks are gonna limit your wheel travel greatly, pick up some rancho's (theres numerous mention of them here in other suspension posts)
body lift approx $130 (keeping in mind im in oz, so about $2 american)
suspension..... ummm (ill keep that figure under my hat, i bought expensive stuff when i didnt know better :rolleyes: )
Mine:
3" Trailmaster body lift
3" t-bar crank/reindex lift up front with 1" BJ spacers
3" lift in rear via JGC coils with the pigtail re-bent out for max height, plus 1" spacers above the coils.
Rancho RS5000 shocks, RS5252 front, RS5116 rear, switching to RS5136 front soon because they're 1.5" longer than the 5252's. I want longer rear shocks too, but I need to make a panhard drop bracket first. THEN you'll see some mad flexing from the ole Pathy. At least in the rear. ;)
yea... sound like my pathy is gonna be about 6 inches higher in about 2-3 weeks... as far as those coil spacers... i just might manufacture some out of an aluminum billet. a good frenn of mine has a lathe ! :aok: i was just wondering if i needed ctrl arms or not.. i guess its fine if the bumpstops are away from the arm.
