Gotrek Posted October 23, 2006 Share Posted October 23, 2006 (edited) I have a 92 SE, When the truck is not running, headlight switch off, the Driver side headlight remains on. With the truck off, turn on the running lights and the headlight goes off, Turn on the headlights and both come on properly. With the truck running the DRL's come on but the driver side is dimmer. I suspect a relay is stuck somewhere. I suspect it's one of the three near the washer fluid jug, can someone pin point the correct one? Edited October 23, 2006 by Gotrek Link to comment Share on other sites More sharing options...
88pathoffroad Posted October 23, 2006 Share Posted October 23, 2006 There are no relays for the headlights. Your multifunction switch(headlight, high beam, turn signal, etc) is sticking. You can take it apart and fix it yourself if you feel like it. This has been covered a hundred times. Link to comment Share on other sites More sharing options...
Gotrek Posted October 23, 2006 Author Share Posted October 23, 2006 There are no relays for the headlights. Your multifunction switch(headlight, high beam, turn signal, etc) is sticking. You can take it apart and fix it yourself if you feel like it. This has been covered a hundred times. Link? I fiddle with the switch it didn't seem to help But I hear a loud clicking from the engine bay which is why I assumed the relay Link to comment Share on other sites More sharing options...
RedPath88 Posted October 23, 2006 Share Posted October 23, 2006 Search... this subject has come up several times in the past few weeks... including yesterday.. or maybe it was the day before. Link to comment Share on other sites More sharing options...
88pathoffroad Posted October 24, 2006 Share Posted October 24, 2006 If you have daytime running lights, there's a module under the hood for that. Link to comment Share on other sites More sharing options...
RI_ChevyGuy85 Posted October 24, 2006 Share Posted October 24, 2006 it's definitly haunted. that is the only real logical explanation. Link to comment Share on other sites More sharing options...
Gotrek Posted October 24, 2006 Author Share Posted October 24, 2006 (edited) No I meant a link to the procedure. I found all the other posts that tell the user to search for his answer but not one with the actual procedure. I have the switch with me but I can't seem to dissasemble it. Edited October 24, 2006 by Gotrek Link to comment Share on other sites More sharing options...
