Driver Side Headlight Remains on
Gotrek
I have a 92 SE, When the truck is not running, headlight switch off, the Driver side headlight remains on. With the truck off, turn on the running lights and the headlight goes off, Turn on the headlights and both come on properly.
With the truck running the DRL's come on but the driver side is dimmer.
I suspect a relay is stuck somewhere. I suspect it's one of the three near the washer fluid jug, can someone pin point the correct one?
Edited by Gotrek
There are no relays for the headlights. Your multifunction switch(headlight, high beam, turn signal, etc) is sticking. You can take it apart and fix it yourself if you feel like it. This has been covered a hundred times.
Link? I fiddle with the switch it didn't seem to help But I hear a loud clicking from the engine bay which is why I assumed the relay
No I meant a link to the procedure.
I found all the other posts that tell the user to search for his answer but not one with the actual procedure.
I have the switch with me but I can't seem to dissasemble it.
Edited by Gotrek
