KyL Posted October 5, 2006 Share Posted October 5, 2006 I understand that there are two modes of 4-wheel drive. 4-wheel high and 4-wheel low. But for some reason i can only shift into 4-wheel low. Is their an indication light saying wether you have 4 low or 4 high on?. The only indicator i get is a little green one located on the guage cluster. Link to comment Share on other sites More sharing options...
RedPath88 Posted October 6, 2006 Share Posted October 6, 2006 Only into 4LO? Well that's a new one, most who have trouble can only hit 4HI Are you sure it's 4LO you found... there is a drastic difference between LO and HI range. All the way forward is 2HI, back one is 4HI. Push the lever DOWN and pull back one for N, back one more is 4LO The indicator light should come on as soon as you shift from 2HI to 4HI. the light simply tells you that you are in 4WD (Hi or LO) is does not indicate which one. Link to comment Share on other sites More sharing options...
FLApathy Posted October 6, 2006 Share Posted October 6, 2006 put it into whichever you can and drive forward (DO NOT TURN IF YOURE ON A HARD SURFACE), if it accelerates close to normal then your in 4 HI, if it it revs up and goes slow, youre in 4 LO. Link to comment Share on other sites More sharing options...
unccpathfinder Posted October 6, 2006 Share Posted October 6, 2006 most who have trouble can only hit 4HI i think thats b/c the directions on how to get it in LO suck...i found LO acciently...just happened to push down on the stick and it fell into place and i was like awsome...i've only had to use it 1 time and that was to show my buddy the most torque she could put down...like 1/2 or maybe 1/4 of what his car puts out but we shot up that hill and he held on tight and said damn so i guess it was good enough Link to comment Share on other sites More sharing options...
94extreme Posted October 6, 2006 Share Posted October 6, 2006 this is only a sticky in this area: http://www.nissanpathfinders.net/forum/index.php?showtopic=6957 :X Link to comment Share on other sites More sharing options...
KyL Posted October 11, 2006 Author Share Posted October 11, 2006 Alright guys thanks. Ill try goofing around with it today on my way to work. I guess the real test is when the great canadian winter hits in a couple months. Link to comment Share on other sites More sharing options...
RedPath88 Posted October 11, 2006 Share Posted October 11, 2006 on my way to work Unless you drive on a dirt/gravel road, don't use 4WD... not on pavement Link to comment Share on other sites More sharing options...
Indigent Posted October 26, 2006 Share Posted October 26, 2006 Just remember though, you HAVE to be in Neutral and completely stopped to get it to go. At least thats how it is in my Terrano. If I have it in Park, and try to go to 4L, it wont budge. It goes smooth as silk when I have it in Neutral though. Link to comment Share on other sites More sharing options...
