sammyb33 Posted October 3, 2006 Share Posted October 3, 2006 (edited) i need an FSM for an 03 dodge caravan (possibly grand caravan not sure) because my buddy is looking for one.... he wants to fix some things like his pasenger window motor, and would like step by step instructions...... thanks -sam EDIT** Replace his passenger window motor.... Edited October 3, 2006 by sammyb33 Link to comment Share on other sites More sharing options...
94extreme Posted October 3, 2006 Share Posted October 3, 2006 dude, your buddy doesn't need an fsm.. it's similar to your truck or any other vehicle.. take panel off.. unhook wireing.. unbolt the window motor.. replace and re assemble in reverse order.. this is basically as easy as it gets. if one is slow, maybe an hour or two otherwise under 30min. and you're welcome. Link to comment Share on other sites More sharing options...
sammyb33 Posted October 3, 2006 Author Share Posted October 3, 2006 eh, i told him that, he just dosent wanna break anything and whatnot...whatever i might just offer to do it for him... thanks MZ... -sam Link to comment Share on other sites More sharing options...
k9sar Posted October 3, 2006 Share Posted October 3, 2006 my 99 grand caravan had a drivers window that decided not to work. Simple procedure... find the screws that hold the door panel in place. Remove them. Pull on the door panel to release the clips that weren't designed to come out. Run out and buy a few new clips. Remove the door panel, unplugging the 2 or 3 little plugs that are keeping you from doing so. Remove liner by pulling. You'll need to duct tape it back on during assembly. Locate window motor... it's that motor looking thing in the middle. Decide how big of a cheapskate you are. 1. buy a new motor adn replace the old one -or- 2. Remove the 2 screws holding the casing with the magnets over the motor shaft. Blow out the carbon dust. SLide the motor guts out from between the brushes (carefully so you don't go 'twang') Look for burnt wires etc. If present, go back to #1 -or- Use a business card to remove the carbon dust buildup that is shorting across the nodes of the motor guts. Reinstall everything. ta-da! works like new. Cost me about 20 min and 0 dollars. Link to comment Share on other sites More sharing options...
