SOL for a lil bit
Extreme90path
Is there a coolant line back or near there that could be leaking?
I had a mystery leak on mine (TBI) and the coolant settled on top of the intake manifold. I cleaned up all the coolant, started and let it run for a while. Once it began leaking again I was able to trace it down to one of the lines that runs to/from the throttle body. (just a weak hose clamp)
Edited by RedPath88
i know on my 87 theres a tube that runs down the center between the intake and engine block and then it has a connection where it splits to the heater core and somewhere else so maybe there? i donno if its like that on the newer models but worth a check
Isnt there a pruge vavle on the intake manifold, up on top? Slick posted a pic to help me out one day, she called it a burper thingy.
edit: On the back driver side.
Edited by FLApathy
