PathFound Posted September 30, 2006 Share Posted September 30, 2006 When I'm filling my '91 Pathfinder with fuel once it's 3/4 full the tank puts up a fuss about recieving more fuel. The nozzle stops pumping fuel and I need to slowly force the last 1/4 tank to get a full tank. Is this normal? Does anyone else have this issue? I never experienced this with a vehicle before. Also, about half the time, when I unscrew the fuel filler cap there's some pressure released. Not a lot of pressure like unscrewing a hot radiator cap, but some obvious pressure where air can be heard coming out. Is there supposed to be a fuel tank vent? Maybe mine is clogged? Thanks. Link to comment Share on other sites More sharing options...
88pathoffroad Posted September 30, 2006 Share Posted September 30, 2006 There's a vent hose from the top of the tank to the end of the fuel filler hose that may be plugged or kinked somehow. That's all I can think of...it should fill all the way up without needing burping. Link to comment Share on other sites More sharing options...
~Ben~ Posted September 30, 2006 Share Posted September 30, 2006 When I take off my filler cap, it releases some pressure also. Never thought anything of it, I don't think its that big of a deal. Haven't had the problem with filling up though. Link to comment Share on other sites More sharing options...
94extreme Posted September 30, 2006 Share Posted September 30, 2006 When I take off my filler cap, it releases some pressure also. Never thought anything of it, I don't think its that big of a deal. Haven't had the problem with filling up though. yeah, i think that's normal. Link to comment Share on other sites More sharing options...
94 Pathy Posted October 1, 2006 Share Posted October 1, 2006 I've never had that problem with my Pathy, but I did have that problem with my '65 Mustang the other month. Went to fill the tank and I was only able to get $3.00 in the tank. Gas was up to the edge of the filler neck. Weird as hell I thought. I began to rock and bounce the car to burp it and it went down a little, but not enough. Drove it for a few miles and looked at it once I got it back into the garage and it was all gone. Yeah, Wierd! I think it has something to do with the filler hose or a huge air bubble or something. Good luck with that. Link to comment Share on other sites More sharing options...
mikemike Posted October 1, 2006 Share Posted October 1, 2006 I've never had that problem with my Pathy, but I did have that problem with my '65 Mustang the other month. Went to fill the tank and I was only able to get $3.00 in the tank. Gas was up to the edge of the filler neck. Weird as hell I thought. I began to rock and bounce the car to burp it and it went down a little, but not enough. Drove it for a few miles and looked at it once I got it back into the garage and it was all gone. Yeah, Wierd! I think it has something to do with the filler hose or a huge air bubble or something. Good luck with that. well with my trans am i notice somthing similar, however it is due to a missing vent assembly, so when i finally filled up my tank gas would spill out, so i rigged up a tube which will prevent it from gettin out which i blow into to clear. i also have to fill slowly, but its for most the way.. and if i fill too fast, and hevnt cleard the tube it will come back out at me. and yes, pressure is normal. many vehicles have warning on the gas cap saying that there may be a pressure build up. Link to comment Share on other sites More sharing options...
