Questions..
Pavelow Leaks
Ok, I got two questions. Apparently either my 4 wheel drive is not working, or im doing something wrong. I've had 4x4's before, but never with automatic hubs, so I put it in neutral, moved the lever down to four hi...light comes on..but no front wheel action. tried rolling it in, tried putting it in from park, nothing. Second, the lever will not even go into four low, or the neutral position for that matter..anybody with any insight, shoot some info my way. Call me dumb, but whatever, I just want it to work.
I answered this in your intro thread ;)
You have to roll forward (or backward) a couple feet after you shift into 4WD (HI or LOW Ranges)before the auto hubs engage... assuming yours are working correctly.
To get it into N or 4L you have to move it into 4HI then push the stick down.  Then pull it back into N and from there you can pull it the rest of the way back and into 4L.
*Make sure you are a a complete stop BEFORE putting it into LOW (or back into HI)
Thanks guys, I figured out the shifter thing by takin the boot off and looking at the gate. As for the no four wheel drive, I took apart the hub and it was put together wrong, I guess whoever was workin on it last had a bad short term memory and could'nt remember how to put it back on. So anyway, its fixed.
