automatic climate control fail
chapter
mine doesnt work that well either and will run the fan at full speed all the time, i dont use it often but whenever i have it has always used the fastest fan setting.not sure if this is the same problem though.
  • 6 months later...
Damn it! I just developed this same problem today! Mine is the SE, but I'm sure it's the same... Anyone know where to get one cheaper or how to repair it? Heck... where is it? Is it the actual control unit/interface?
Yeah, it's not to bad to if it's the blower motor resistor, which, is replaced by the blower amplifier in a Climate Controll equipped Pathy/QX4. Unfortunately, I don't believe the 2 are interchangeable.
  • 3 weeks later...
Well, this was IT! The straw that finally broke the camel's back, or at least the one that made me trade-in the Pathy. I decided that I was tired of the limited aftermarket support and rediculous prices for replacement parts and the frequency of failure... and the lack of a bed...
I now have a '07 Frontier SE 4x4 Crew Cab Long Bed with the 6spd.
I'll still be lurking around the forum so I'll "see" you around.
