lee_cha_nin Posted August 24, 2006 Share Posted August 24, 2006 Hi, I have 2001 Pathfinder and (quite new to it) recently the backlight behind the speedometer/fuel gauge has started to loose contact. How do I access the bulb/light? From the hood or?... Thanks, Nick Link to comment Share on other sites More sharing options...
vengeful Posted August 24, 2006 Share Posted August 24, 2006 Check your dimmer switch. If it is the bulb, you have to remove the cluster to get at it. You can't get at it under the hood. Link to comment Share on other sites More sharing options...
lee_cha_nin Posted August 24, 2006 Author Share Posted August 24, 2006 (edited) It's not dimmer. Only left part of the panel doesn't have light...During the night drive, I can see my RPMs but not my speed. And it comes on/goes off while driving over a bumpy road. Edited August 24, 2006 by lee_cha_nin Link to comment Share on other sites More sharing options...
GrimGreg Posted August 24, 2006 Share Posted August 24, 2006 Yeah, to get at it you have to pull the cluster out and change the bulb. I'll let an R50 owner explain how, I have no idea if they are like an older Pathy for dissasembly. Link to comment Share on other sites More sharing options...
vengeful Posted August 25, 2006 Share Posted August 25, 2006 They're not at all Ryan. You have an answer in your post in the R50 section. I'm going to merge the threads after a little while. Link to comment Share on other sites More sharing options...
unccpathfinder Posted August 25, 2006 Share Posted August 25, 2006 hmm my older trucks...when it goes out i slap the dash and it comes back on : they're getting good at hiding screws and what not to remove things so be careful if u go to pulling things apart... Link to comment Share on other sites More sharing options...
