87pathfinder4banger Posted April 17, 2004 Share Posted April 17, 2004 i was reading on a website (Nissanoffroad.net) that on a Pathfinder you can give it up to a 2 inch lift by adjusting the torsion bar. does anyone know if this is true? and if so, the website doesnt specify, but is that a newer Pathfinder or older one like mine. if someone could help with this it'd be great. Link to comment Share on other sites More sharing options...
87pathfinder4banger Posted April 17, 2004 Author Share Posted April 17, 2004 what im saying is that i basically want to know a cheap and easy way to put some sort of lift Link to comment Share on other sites More sharing options...
statikuz Posted April 17, 2004 Share Posted April 17, 2004 Yep, you crank the torsion bars and you can get 1"-2" of lift IN THE FRONT, but it plays hell with your alignment/steering. If you want to lift it much more than that the generally accepted solution is to get new [longer] UCAs to allow your front suspension to be realigned to spec. For the rear you'll need new springs. Your choice of those. Link to comment Share on other sites More sharing options...
88pathoffroad Posted April 17, 2004 Share Posted April 17, 2004 Actually, you can get more like 2.5-3" out of the stock front, but it'll be riding on the bumpstops and you'll have no downward suspension travel in the front. It will need an alignment afterwards, for sure. Link to comment Share on other sites More sharing options...
statikuz Posted April 17, 2004 Share Posted April 17, 2004 Yeah, I meant 1-2" safely and without having to deal with any problems... most people like some front suspension travel. =) Link to comment Share on other sites More sharing options...
