nick1716
Everything posted by nick1716
  1. well i know how to weld..thats what im in skool for but on toyotas you dont need to do any welding...its just like a body spacer pretty much... like 2-3 inch in diameter by 2 inch thick (or how ever much drop you want) with a hole drilled in the center
  2. drop your front differential lower so your cv joints arent at that bad of an angle
  3. is it possible to do a diff drop on a pathy??? like 4runners and tacomas?
  4. your fine with the flares..they just rub on the plastic liner and you have to trim your fender on the side closer to the door
  5. well i talked to the guy today and the guy said he had it in stock and they shipped it out today so it should be here monday or tuesday according to the guy. so lets hope it is!
  6. has anyone in washington ordered the AC lift?? how did it take to get? (im excited to get mine haha)
  7. i know its not mud..its long metal mounts wiht a rubber top. it kinda lookjs like my buddys on his 4runner
  8. am i lookin at somethin weird is there 2 sets of bump stops on r50s...iknow theres some in the coils but it also looks like theres some on the axle.
  9. i dont even use it i drilled holes and zip tied mine on
  10. yea im dumb...forgot to hit "1" first
  11. i called AC and it said the phone was disconnected. are they outta business or only taking orders online? or what?!
  12. maybe the unibodys cant handle as much as the body on frame??? i dunno either
  13. the driver side might sit lower do to a full tank of gas??? the gas tank is on the drivers side
  14. whered you get the freeway blaster horns and how much were they?
  15. the rs 5000 work fine...part number is 5118 for those
  16. here is where i mounted my antenna..i just got a toyota mount thing and bent it a tad and it works great
  17. what do these horns look like? and how easy are they to hook up
  18. thanks 88..and trailsin it sounds like you take really good care of you rig...i only get my tires balanced once and rotate em about every...actually i have never rotated them..i havent had a set of tires for more than 5k miles haha i keep goin bigger!
  19. when you get your car aligned after its been lifted do they fix the camber angle?
  20. i mounted mine on the inside of my bumper, in front of the washer fluid box and its loud enough.. my buddy has his in the engine bay of his 4runner and its just as loud
  21. yea haha and random pedestrians is fun too! great fun in the PA you should really get to it and intall it!
  22. actually the back one is easy to open up, you just open the back hatch you and pull on the side plastic and unsnap all the little plastic snaps all the way upto the seatbelt
  23. well my seatbelts dont retract worth crap...only about half way... is there any way to make them retract better so i dont always close em im my door??
  24. only if you want to use the PA... but otherwise theyre built in, and theres also a plug in the back for the option of using a better external speaker instead of the built in one
