93xe
About 93xe
  • Birthday 05/20/1983
    97 XE Auto - 174,000 '02 SE roof rack/tails AC Lift 32" BFG ATs 15x8" Summit alum wheels Warn Hubs Weapon R Intake 2.25" cat back Flowmaster 40 series KYB/Bilstein PIAA headlight/ foglight bulbs Pioneer AVIC-Z head unit JL Audio HD 5 channel DIamond d6 components (2) Alpine type r 8" Viper 2 way pager security/remote start
    XE
Contact Methods
  • Website URL
    http://
  • ICQ
    Philadelphia, PA
  • Interests
    12v
4,856 profile views
93xe's Achievements
NPORA Veteran (3/5)
6
  1. Guys the only bulb that can safely go Into the oem reflector housings is, unfortunately, a halogen bulb. Hids in stock housings are blinding and glaring no matter how you adjust them. Factory hid projectors have that "crisp" cutoff line for a reason - so that no light goes above that line and blinds oncoming traffic. Plug and play led bulbs are also a bad choice, and have been proven to throw less light down the road than normal oem.halogens. leds will appear "brighter" but actually have less output, and have a terrible failure rate since becoming popular. Using leds or hids in reflector housings is just as bad as using the popular led light bars and pods as aux lighting on public roads. The only proper way to improve your headlight output is, as posted, upgrading to a higher quality halogen bulb (silverstar, zxe, night breakers), or do a proper HID projector or led projector retrofit. Sent from my SM-G928T using Tapatalk
  2. To access the ebrake wire in the vehicle, remove the center console and splice into the wire at the ebrake connector at the base of the handle.
  3. id electrical tape the hell out of all those connections and then heat shrink them just to be safe...
  4. awesome, that is more info than i've found in a year of searching. Thanks! Time to get to work
  5. I have been searching for some kind of wiring guide for a while now. My terrano projectors came without bulbs or plugs, and the switch I posted with a harness. Getting the headlights to work shouldn't be abig deal, but I really want to figure out how to make the leveling switch function correctly.
  6. I have this switxh that came with my pre facelift terrano projectors Sent from my SGH-M919 using Tapatalk 2
  7. usually pressing lock 3x will start an aftermarket remote start system from a factory oem remote control
  8. i see these topics all the time but never remember to post a response. If you are changing your radio, the best thing to do is upgrade all the speakers adn ditch the bose blows crap. In most bose equipped pathys, there is a bose amp in each front door for each front speaker, and a single driver side rear quarter panel mounted blows amp for the back doors. bypassing these amps couldn't be easier...you simply can jump the inputs to the outputs. When you unplug the factory radio, find what colors go to what speakers (easier by plugging in an aftermarket nissan wiring harness, metra part # 70-7550). Write these colors down...i.e. Front left-blue/orange, etc. Pull all 4 door panels and remove all speakers. IN the front doors, at the bose amp (small box attatched to the speaker mount) look for the wire colors for that speaker that you noted behind the radio. cut these wires BEFORE the bose amp, attach new speaker leads, and plug them in! Viola! amp bypassed. For the rear amplifier, do the same. track down the factory output wire colors, jump them at the amp to the colors of the rear door speaker wires, adn done. Your sound will greatly improve. I highly recommend installing a 6.5" seperate (component) speaker in the front, with the 6.5" midbass in the door and a tweeter in the a pillar. A great sounding cheap set would be Pioneer TSA-1605c.
  9. This is what I plan to get as soon as funds allow...190 amps http://www.maniacelectricmotors.com/hiou190ampal3.html
  10. they are advertised as fitting 2001-2004, but they fit my 97 just fine, hook into the clip on the driver floor, and say pathfinder on the front ones.
  11. if anyone is interested, i just bought a set of brand new r50 rubber all season nissan mats on ebay. seller has a few left. http://www.ebay.com/itm/2001-04-PATHFINDER-4-PIECE-BLACK-RUBBER-ALL-WEATHER-FLOOR-MATS-999E1-VN000-/330869823350?vxp=mtr got to my house in 2 days, fit perfectly i have been searching for a set of these for over a year
  12. if you have any 12v wiring experience at all, its not too difficult. 99% of the wires are under the driver side dash at the ignition harness, and at the secu (security control unit) to the left of the steering column. Tach signal is underhood as well as hoodpin.
  13. lock the doors with the remote, wait 30 seconds then open the door if the horn starts honking and lights flashing you have an alarm. Hook up arm/disarm if you want the factory alarm to work with the remote. that unit should have negative door lock outputs already no need for relays...almost all of your wires will be at the keyless/security module under the ds dash to the left of the steering wheel.
  14. kenwood navigation units use a garmin nav
  15. nothing is impossible, certainly not this just not worth the time and effort first of all the oem gps antenna is built into the car, and does not usually work with aftermarket style gps antennas. The oem nav needs to see vss (vehicle speed sense), brake, ebrake, and other signals, many of which may be altered by computer control, making it difficult to just hardwire these into a new vehicle Unless the altima came originally as a radio delete car, chances are the factory radio is not a true double din size, requiring extensive modifying to fit (although it would bolt to the stock brackets no problem) There are many more reasons not to undertake something such as this With those dodge radios they were just am/fm and cd or tape source, not a touchscreen with navigation Aftermarket is waaaay more upgradeable than oem any day of the week Aftermarket will look better, sound better, and generally work better than an oem unit (even though most are built by the aftermarket companies) People always spend too much time trying to integrate factory equipment into older vehicles when a much cheaper higher performance solution is readily available. End rant PS sorry just got done working a 17 hour black friday and a loooong saturday
