shift220
shift220 last won the day on August 27 2017
shift220 had the most liked content!
1996 SE. KrFabs 4" Lift kit
Skilled/Experienced Mechanic
1996
Gender
Edmonton, AB
7,142 profile views
shift220's Achievements
NPORA Fulltime Resident (4/5)
7
First off I want to thank everyone on this forum for the support over the years. We became less and less active on this forum as we sold the original pathfinder and became generally busy with life. As a result we have stopped producing all the products we sell online. This was a part time job for two of us working out of a 800 sq-ft shop. We were glad to produce many kits that were sold around the world including Russia and Australia. We have 12 kits left to send out. They are fabricated & packaged ready-to-ship. Included in the kit is the following: Base Lift Kit (all 4" spacers required for the front + hardware) Extended Brake lines front and back WJ rear spring adapters Panhard Drop bracket The steering linkage is not included as it is cheaper for the end user to purchase it themselves (since we aren't putting in a large order for these last kits). Pricing is as follows: $650 CAD (Approx $500 USD) $90 CAD Shipping to US $50 CAD Shipping in Canada If you are interested in picking up one of these kits, please email us at info @ krfabs.com We also have 2 "missing links" in stock. These are $65 CAD + $20 to ship to US ($15 in Canada) Any questions might be answered by our FAQ section found here: Link
Rick, I'm not even sure on a count of kits so far. Lots were sold before KrFabs was even started! It's well over 30 though. Everything we ship goes Canada Post -> USPS since it is the cheapest option by far. These kits weight up to 44 lbs. I'm on vacation right now... but I'll try my best to keep up on emails
Kit should be going out Monday. Thanks for the order! We have three kits going out that were ordered last week. One going to Russia and another one that will ultimately end up in Panama! I think that puts us at about 6 different countries that we've sent kits to.
Timmons, I made the brackets and mounted the stabilizer. I would have to dig up what the stabilizer came off of. The brackets were a one-off and they would need some R&D so I could produce them for the public. Same goes for the clamp on the tie-rod. The biggest problem is that the install doesn't allow you to put the "rear" bolt into the subframe because the shock is in the way. This will probably have to wait until spring, since my friend is using the Pathfinder as his winter beater.
I put this on the backburner for a while and the pathfinder is now daily driven by a close friend (I have a DD frontier for work). I'm glad this came up though because we are now setup with our cnc plasma table so these brackets I can rapid prototype and the rest is relatively easy.. I will get this going again!
Looks like some really beefy links! You'll never bend a set of those with the size of solid aluminum you are using. I would expect to "feel" more of the road since you have eliminated the rubber cushions, but for most offroaders this probably wouldn't be a huge deal. A good option would be to swap out the body side heim for a poly bushing. Nice work
A cheap and easy solution would be to sleeve the rods. I would slip a 4-5" section of 0.120-0.188 wall tube right in the middle and weld the ends. If you can't find something that is a friction fit, I'd plug weld it every 0.75"-1" along the length. I'll see what sort of price I can get on MOOG inner's and the cost to sleeve.
Just run a relay off the wires coming out of the converter. Take the load off the converter entirely. Also check your trailers for shorts (and put a fuse between the converter and the trailer).
What sort of trailer is this? Generally trailers that have brakes / batteries need a 6 or 7 pole plug. I wouldn't say that the signal lights run off the aux power though. They may still use power from the signal wires. The difference is that a 7 pole includes a brake wire (from the brake controller), back-up lights and a 12v constant. When I wired up my 4-pole on my R50, I used relays on all the circuits. I also had to buy the converter to get the brake lights together. Anyway, if you think you'll ever need to pull a trailer with brakes, I would go for the 7 pole and just run adapters off that. I like the round plugs because the terminals are protected (unlike having a flat-4 hanging in the air).
Yup, the center bore is to small. You'll need to get it bored out to the Pathfinder size.
Nice If I ever have a customer with doubts about the strength of the SFD kit, I simply show them some pics of your wheeling and the concerns seem to disappear.
Those "adapters" I made the first time worked well but aren't easy to make. The KrFabs adapters are much simpler in design and that's why they are cheap. We could probably make a adapter/lift combo, but the WJ springs are readily available in different lifts.
Looks good! The bolts for those adapters are 1/2" How do you like the ride with the springs? Those pics are good for what I'd like to do with them. Thanks!
It's pretty simple really.. they want to take the risk of the initial investment out of the equation. It also means they don't have any interest in making a kit for the R50. It's to bad since they would be the only company with a system available and they have a huge distribution network that would reach 1000x the people on this forum. While 15k does seem high, its not unreasonable. That's an extra $15 per kit if they sold 1000, $30 if they sold 500, $60 if they sold 250, $100 if they only sold 150. Really not much if the kit is $600+ to begin with. Oh well!
Are the rear shocks on the 01+ 14mm on the axle side and 12mm on the body side (opposite of the 96-00?)
