Everything posted by ctpathy
Coming home the other night my headlights went out then came back on then out again. I smelt some bruning plastic but could see where its coming from my dash an a/c was effected by the head light prob. any thoughts let me know thanks Brian
Looks great good job pezzy
I just replaced the tach I got from the j/k and that solved the problem.
check in NOPRA services we have a member who works at a nissan dealer his name is rob thats where i got mine
I have a 95 and my son has a 91 both heaters work great. and we are in newEngland
Kingman I agree with you on Chyrsler service. W e had 98 interpid the battery went dead so I said put a new one in. You wouid think the dealer would put the right size battery in wrong. They put the wrong size in and the battery was moving al around in the battery box. Thats when we switch to nissan instead of another mopar.
Well I put on the 265/70-16 General Grabber A/T's lastnight
ctpathy replied to Justin517's topic in 96-2004 R50 Pathfinders
Yeah there's lunch time LOL -
I have them in my 95 , drivers side anyway pass side I have to look at.
On my sons 91 has a very rough Idel when it warms up could this be a co censer it has new plugs but still has the old cap and wires Thanks for any help with this prob. thanks Brian
I have a 95 and had the same tach problems. I replaced the tach from one i got at a JY and that fixed problem. But now I can't get the light to work in my clock. And yes I replaced the blub and still does not work, Do guys think it maybe the circuit borad.
Hey guys I'm trying to find out what size bulb that's in the clock on my 95 and does anybody have the clear plastic that goes over the gauge cluster I broke mine replacing the tach. Thanks for your help Brian
You guys where right it was the relay. Thank guys for all your help ctpathy
Maybe someone has had this problem. I have power going to the fog lights the switch lights up and the lights are brand new. I also checked the two 15 amp fuses and are good so i'm out of ideals. hope someone can help thanks ctpathy
hey lax the pathy is looking great love the wheels
I never owned a R50 . So I am doing it right by having a WD21 LOL Thanks for the help
I cleaned the battery connections moved the shift lever and bang she started . the pos connect is still a little loose i am going to replace it thanks simon and evreyone for the help.
OK my pathy won't start, I turn the key and get nothing. It is in park and when I turn the lights and turn the key nothing the lights do not dim so i ran out tricks has anyone have this problem??? thank for any help Brian
$4+ a gallon - what's your personal solution
ctpathy replied to Mr. Pickles's topic in General Forums
I only travel 11miles to work ( one way) so i use my harley) 06 roadking classic as much as possible -
you where right, There was a break in the wier thanks for your help Brian ctpathy
Hey guys My son has a 91 pathy and he has a squeel when it warms up and at 3000 rpms. We have changed the ideler pulley with a used one has this happen to any of you. thanks for all your help Brian aka ctpathy
I will check it out thanks
The fuse is good the light works when u open all the doors execpt the drivers door??
Hey guys Maybe someone has had these problems with their 95 and could help 1 my dome light will not work on the driver's door. yes i got a new door switch, but have no power going to the plug all other doors work fine? 2 My tach seems work when it wants to any thoughts ? Thanks Brian CTPATHY
Gald you are ok Brian but it looks like a small dent u can fix it
