Everything posted by boothill2008
We have limited most of our tows to below 4500 lbs, the majority being either my son Nick's '68 CJ5 or my '66 CJ5. To improve the suspension and braking, we have Brenbo slotted and drilled rotors with upgraded brake pads that we ordered from Stillen, and Rancho 9000 air adjustable shocks. I just replaced the torque converter last year, but otherwise it has done a decent job..... Sent from my SM-T813 using Tapatalk
Hi!! I drive a '93 Pathfinder that has been modified for towing, but your 2008 should be setup better right out of the gate. Since you have the SE, you probably have the 266hp V6 unless you opted for the V8. As the SE is rated for 7000 lbs, you should have no problem. Since the WD21's like mine have a more delicate transmission, I always make sure that it has had a trans fluid change yearly at a minimum. Looking at your shift selector, it appears on the left side just below the release there is a button. On my WD21, this is red and keeps it from popping in and out of overdrive when you are towing. I would check this out, and use it when you are towing if I am right. Since I have toasted 2 transmissions on different cars over the year, I would make sure that you have a trans cooler installed, the larger the better. Nothing kills your transmission like hear. In line with that, if you notice your transmission is shifting frequently, try adjusting your driving habits and speeds to minimize that. If it continues to shift often, I would consider one or two rest stops along the way to allow the trans to cool. Make sure you install a quality electronic brake controller, and try not to "ride the brakes" whenever possible. Hope your Dad enjoys his trip!! Take care - Boothill2008 Sent from my SM-T813 using Tapatalk
I'm having issues with my power windows and door locks. They will work fine for a few days, and then without warning, stop working which can be a problem when the windows get stuck down. I tried replacing the master switch on the driver's side with no effect. When I use the alarm fob, I can hear a low volume noise like a connection is being made, but the door locks will not work....the alarm will operate though. I heard through the rumor mill that it is typically a ground problem on the WD21, but I'm not sure where to check? Any thoughts?
Finally! Legos on the Pathy with BFG All Terrains, love them!! Just did the Mohave Road!!! :)
Love my SE's, I'm on my 3rd! Just put legos and BFG All Terrains back on my SE (Sorry MotoIQ, but the Volks racing wheels are still in the garage!). ;-)
No hate here, I love driving my sons' (member 92Path_68CJ) 1968 Jeep CJ5, it is a real kick! Gets lot of positive comments too, but I will always have a Pathy!!! Enjoy and Good Luck!!
First was grey, second white, third green.... Sent from my SCH-I535 using Tapatalk
Wow, I loved following this adventure that you posted for us!! I think most of us on this forum can appreciate the affection that you have for your 22 year old truck.... I cannot seem to get them out of my system, having just purchased my 3rd a while back (this one's a keeper!!). I am even planning to get another to build and off road!! Enjoy driving your old friend!! Boot
She should be fine with RHD.....
Pathfinder project on Extreme 4X4 T.V. show? UPDATE
boothill2008 replied to jitterymonkey's topic in General Forums
Nice to see another project truck went to a good home!!!! -
I prefer the forum as the Facebook page is not as well organized, nor does it contain the information that the forum does....I absolutely do not see the forum as dead... Sent from my SCH-I545 using Tapatalk
Snow! Sent from my SCH-I545 using Tapatalk
We can make it better, we have the technology...
boothill2008 replied to PerlNinja's topic in General Forums
Hi PerlNinja! If your right foot is getting hot when you drive, it is probably a sign that you need to replace an exhaust gasket. Nissan, in their infinite wisdom, decided to join an exhaust pipe under the driver's side floorboard not far from the gas pedal.... How I found mine was I placed my Pathy on jack stands and crawled under and had my son start it, while holding my hand around the junction. I could feel the exhaust leaking from it as I moved my hand around the area. If it is not the gasket, it may be a hole in the pipe. Make sure the car is cold when you do this so you do not burn your hand. I would send you a gasket, as I had one laying around but I lost it in my last move. Give it a try and let me know what you find? Take care.... -
Sunroof Shade /Cover where can I get this! or Part #?
boothill2008 replied to gsumann's topic in 86.5-89 WD21 Pathfinders
I would message them to find out, I do know that they are hard to find used.... There are a lot of Pathfinder's around with them missing. -
Liftgate supports removal mission impossible
boothill2008 replied to turbonegro's topic in General Forums
I would also be careful when working with the struts, I was investigating the strut mount on my 92SE and I assume that the threads on the liftgate door itself were accomplished via spot welding a nut of some type on the inside of the liftgate. I accidently applied pressure on the strut when it was partially unscrewed and the part with the threads popped off and fell inside the hollow area of the liftgate door. For years after that I resorted to using a dowel to prop the door open.... -
Hi Norcal200486, Aside from the solutions above, my first Pathfinder had a lot of problems with California Smog requirements at about 230k miles. If you are unable to solve the problem on your own, California can help you with the cost of professional repair, there are specific requirements for the program, see this link, they will assist you with $500 towards the repair: http://www.bar.ca.gov/80_BARResources/01_CAP&GoldShield/Factsheets/English%20RA%20FAQs.pdf
95 pathfinder tranny shifting funny need help
boothill2008 replied to billpittman's topic in The Garage
I would echo what Precise 1 said, I have sent 2 Pathfinder's trannys to the boneyard and can vouch for the fact that you have to take care if you are experiencing a problem.... -
I've had 3 SE's, just worked out that way.....so no experience with XE's
Welcome to the forum! That is one clean Pathy, you are very lucky!! I like your plans!!
My 93 SE is at 176,000 miles, about 54,000 on the engine build.....
Like the tires!! Met with a new lady tonight, she made major points telling me my Pathfinder looked like a classic car!!
Don't get me wrong, I am gonna keep'em in my garage with the more street oriented tires, but I don't really want to bang'em up off road. They cost a bit of change....
Adam, I was faced with slim pickings out here for a decent Pathfinder, so I was putting together a plan to upgrade one to include the Xterra trans. Well, after my son talked me into looking at the Project Pathfinder rig that was for sale at the time, you know the rest of the story!......
New tires and an alignment make Pathfinder a happy 4x4!!!
