DesertEagle
About DesertEagle
  • Birthday July 15
    My '88 pathy. First car I've ever had. Currently running with 200k on it. Most parts are OEM at the moment.
    Screwdriver Mechanic
    Rarely Go Off-Road
    XE
    Arizona
  • Interests
911 profile views
DesertEagle's Achievements
  1. Are these type of swaps uncommon or am I not looking with the right keywords or something? Would such a swap be too excessive in cost and function for what the Pathfinder is capable of and can already handle with the preferred VG33 swap? Only reason I ask is because the thought popped up out of curiosity one day as I was browsing the web for different types of engines with their general info/common problems. One thing lead to another and I eventually stumbled onto some article recommending V8 engines worth swapping for off-roading (for any 4WD-capable vehicle in general mind you, not specifically geared toward the Pathfinder). It got my gears grinding a little harder and begun to peak my interest in swapping out my VG30i engine down the road eventually, but it made me ask the question of whether a V6 or a V8 would give me more opportunities to access certain trails or just let my Pathy have more utility (better towing handling, increased towing capacity). Most topics I've pulled up both here on the forum and elsewhere on the web seem to favor the VG33 engine and variants because of it's relative ease of installation and specific component compatibility with the VG30 engine family. As for the performance difference, I'm still clueless. But I've yet to come across posts, articles, blogs, vlogs, videos etc. from people who've swapped anything higher than a V6, although that's not to say that I haven't seen some suggestions thrown around like an LS swap or something similar. Sent from my SM-J727T using Tapatalk
  2. Interesting idea! My '88 is an auto so I'd be curious to see if the same swap would work with just the right amount of tweaking. I'm heading over to the yard tomorrow with my bud so I'll keep an eye out of there's a GC somewhere in the lot. Sent from my SM-J727T using Tapatalk
  3. I've got to make some time to crack open that cluster and see what's going on inside. I'll be heading over to the junkyard tomorrow morning with my buddy to pick some parts he needs for his car, so I should have some time to do it then. I'm hoping I get lucky that there's a first gen Pathy somewhere in the yard that has an intact cluster that I can salvage from. I'm up in North Valley. I'll send you a PM so we can work out the details in case I dont end up stumbling on any Pathys tomorrow. Sent from my SM-J727T using Tapatalk
  4. Just as the title says. Both stopped spinning about a month ago. Haven't been able to make heads or tales of what the cause is. Started with the odometer first. Travel odo went out at the same time so it isn't spinning either. Speedo went out near the end of the month. Anybody ever had to deal with an issue like this before? Should I consider replacing the gears inside the cluster? My '88 is running near 200k on it so I wouldn't put it past the idea that those gears are busted/ready to bust. Sent from my SM-J727T using Tapatalk
